Results 1 to 10 of 10
Thread: Any bearing experts?
22nd Aug 2021, 04:17 PM #1Diamond Member
- Jun 2010
- Canberra
- 1,322
Replacing this bearing and a bit mystified as to how the the tiny hole in the bearing is meant to stay lined up with the grease hole in the housing?
I can install the bearing so it does align and take grease, but there seems nothing to stop the bearing rotating out of place, and then not take grease.
In other housings I've seen an internal groove cut that would account for this, but no such feature in this one...
22nd Aug 2021, 04:33 PM #2Gear expert in training
- 34
- 1,079
That's the outer race, right? Shouldn't it be a press fit in the housing then? Not much point in having rolling elements if the whole bearing can spin...
Or am I missing something?Gear cutting specialists and general engineers www.hardmanbros.com.au
22nd Aug 2021, 05:19 PM #3Diamond Member
- Jun 2010
- Canberra
- 1,322
The upper bit is the outer ring (it's the old, failed bearing with no guts) the outer surface is spherical to allow the bearing to self-align. The housing below is spherical on the inside, and gets pressed into place in the machine. There's clearance slots in the housing to allow the bearing to be inserted and rotated into place, but there's plenty of tales from the bearing shop of people who didn't realise this and have tried heating the housing and pressing the bearing into place
22nd Aug 2021, 05:27 PM #4Gear expert in training
- 34
- 1,079
22nd Aug 2021, 06:54 PM #5
22nd Aug 2021, 08:00 PM #6Diamond Member
- Jun 2010
- Canberra
- 1,322
The housing is a press fit into the machine (has straight, parallel sides), but the bearing is *not* a press fit into the housing, as its outside surface is spherical.
This video shows a flange version of the housing, but the bearing, and the method for installing it, is the same. Note that with the housing in the video, once the bearing is removed, there's a grease groove. The housing I'm dealing with doesn't have that.
https://www.youtube.com/watch?v=1jG5...l=SKFPartsInfo
22nd Aug 2021, 08:02 PM #7Gear expert in training
- 34
- 1,079
Ohhh right, now I get it
23rd Aug 2021, 11:37 AM #8Senior Member
- Apr 2018
- 168
That bearing looks like the tiny ball retainers is missing. they may not be grease holes as you think.
https://partners.conbear.com.au/Product/info/C209ECO
23rd Aug 2021, 12:35 PM #9Golden Member
- Apr 2018
- Drouin Vic
- 634
Definitely not an expert but I'm familiar with the 'P' and 'F' style housings that use the same spherical self-aligning bearings (pillow block and flange mount; no idea what 'C' would be short for), the grease hole doesn't have to be in any particular location as there's clearance in the housing for the grease to get from the nipple to the bearing. The locating ball on the bearing is located in one of the slots in the housing and the bearing is rotated into place- the grease hole ends up wherever it ends up.
Without the grease groove, is there some less obvious form of clearance between the housing and the bearing, like a variation in the inside radius?
23rd Aug 2021, 02:19 PM #10Diamond Member
- Jun 2010
- Canberra
- 1,322
The other end of the shaft has a flange bearing housing, and it has a groove for the grease as per the SKF video.
Without that tiny grease hole lined up with the corresponding hole in the housing, you cannot get grease into it - I tried very hard with a couple of different grease guns. Now that I've dismantled the machine, removed the bearing, lined up the holes and reassembled it, it takes grease just fine, but that was many hours work.
Rivnut/Nutsert Experts?
By RustyArc in forum METALWORK GENERALReplies: 54Last Post: 16th Oct 2017, 09:06 AM -
Any Hercus Experts?
By orm255 in forum THE HERCUS AREAReplies: 1Last Post: 28th Jun 2017, 03:47 AM -
Question for the VFD Experts
By Auskart in forum METALWORK GENERALReplies: 5Last Post: 9th Jan 2016, 12:57 PM -
Tramming question for the experts
By eskimo in forum METALWORK GENERALReplies: 13Last Post: 12th Mar 2010, 10:15 AM -
Engineering experts - what is this?
By volvomad in forum METALWORK GENERALReplies: 10Last Post: 19th Feb 2009, 07:27 AM
