Results 1 to 15 of 18
17th Aug 2021, 01:12 AM #1New Member
- Aug 2021
- Netherlands
- 30
- 4
How to design/build a sheet metal tube?
Hi all,
I'm designing an enclosure which consists of a sheetmetal tube (1.5mm, about 14 gauge) clamped inbetween 2 3-printed plates.
The only problem is that I have 0 experience with sheetmetal design. I've been reading up a lot, but I struggle with figuring out how to build the tube.
The idea is visualized below:
The tube should be around 250x175mm (10x7"), and about 600mm (2ft) long, the radii of the corners is roughly 17mm (2/3").
Now, I understand the sheet metal can't be folded in one go the way it's drawn here, but in what way would it be possible?
Ideally, the tube should be as smooth as possible (so no overlaps etc.),
Would it be best to fold two U-shapes and weld them together?
Any help would be incredibly appreciated!
17th Aug 2021, 07:49 AM #2Philomath in training
Welcome to the forum
TIG welding would be the way to go, start with lots of tacks and then fill in the gaps - there will be some distortion though but a skilled welder should be able to minimise that.
For the folding, I would have the joints on the short sides. Large radii curves like that can be done on a bench (for a one off) by clamping the metal between the bench and a piece of pipe or barstock of around the right diameter and then folding the metal around it. I'd suggest trying it with scraps and a piece of something, just to work out the technique. With the thickness and the length you are talking about it won't be simple, so levers and hammers maybe involved...
17th Aug 2021, 11:20 AM #3Novice
- Apr 2013
- Mornington Peninsular
- 23
A Magnabend folder (or clone) could easily fold this from one piece of sheet requiring only one weld. A quick look at some YouTube videos will show how it’s done. Don’t know if you’re looking to do this yourself or wanting to pay to,get it made for you. I would think most sheet metal fabricators could do this for you.
Leigh
Sent from my iPad using Tapatalk
17th Aug 2021, 01:06 PM #4
Hi Gwalb,
Welcome to the MetalWork Forums
We have many distinct areas of metal work you will be able to explore .
To find them simply do the following:
Goto the FORUM box in the top left hand cnr of the page and click the down arrow. This will bring up a pull down menu that has Forum Home at the top
Click Forum Home which will present a scroll down page.
Our rules,the Terms of Service are right at the top , please take the time to read them. Here is the link for TOUs
https://metalworkforums.com/f90/t197...terms-tou-read
Below that are all the various areas and sub forums that make up our MetalWork forums.
If you want to post pics in your first ten posts sometimes our moderation kicks in I may have to moderate them manually.
Welcome
17th Aug 2021, 07:25 PM #5Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
17th Aug 2021, 09:57 PM #6=GWalb;1988244 The only problem is that I have 0 experience with sheetmetal design. I've been reading up a lot, but I struggle with figuring out how to build the tube
Do you merely want to design the the unit with a view to designing it for the best possible process to be utilised?
Do you design other things and just this time are seeking the how to's with eventual production in mind?
How many units would you like to make. For instance, if you were making hundreds or thousands , 2 halves could be made with a press and die and tig welded or
or
Do you want only to fabricate the unit as a single one off for yourself ? Are you just seeking an insite on the best procedure and the tools to do the job?
With a bender be it magnetic or not, the bending effort increases as the length increases hence the preceding comment from Techo 1.
If you are an absolute newcomer to ( sheet) metal working it would not be a good first project. What you describe can't be made in the average DIY garage or shed.
The tools/equipment are not cheap so the choice of using a sheet metal fabrication shop might be a good choice.
17th Aug 2021, 10:02 PM #7
Hi GWalb,
Two pressed half’s stitch welded together !Best Regards:
18th Aug 2021, 02:48 PM #8Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
That can be done relatively simply from one piece using a sturdy bench and a fairly easy to manufacture former.
600mm of 1.6 over an 8.5mm radius (17mm corner) is not going to be all that difficult (even less so if its R 17mm).
18th Aug 2021, 07:40 PM #9Golden Member
- Sep 2008
- 838
18th Aug 2021, 09:27 PM #10Most Valued Member
- Mar 2011
- 1,552
Stitch weld a round bar to a flat bar on edge. Clamp the sheet between the bench and the bar using a couple of clamps, pull the sheet around the round bar. If the bar slips weld a couple of angles on the ends to provide a flatter surface.
If you fold the two corners that have the weld seam between them first you can then fold the other two to form a square.
Same way you do it on a Magna bend, just without 5k worth of machinery to do it.
I have a fixture table with a 30mm thick top that’s gridded with M12, so I just drill the ends of the rods and bolt them down.
Ron Covell did a video demonstrating a similar set up if you search for his radius bending video.
18th Aug 2021, 09:39 PM #11Most Valued Member
- 70
- 1,513
18th Aug 2021, 11:40 PM #12New Member
- Aug 2021
- Netherlands
- 30
- 4
Thanks everyone! I'm really amazed by the amount of replies.
Also, sorry for not being clear on the purpose of the project.
The idea is to design an enclosure for a special purpose (marine) lithium battery.
First, I'll make 2-3 'prototypes' which I'll sell to a friend.
After that, the idea is to build/sell more (if everything works out).
My first plan was to DIY, but reading your replies makes me inclined to pay a visit to my local metal shop.
The Magnabend looks like it's exactly what I'll need, making 4 folds and the having one tig weld would be perfect. I looked up the specs of the Magnabend, and bending 1.5mm aluminum over 600mm shouldn't be an issue.
I might try the DIY bench setup if my local shop doesn't have a Magnabend (or if it's expensive to have them do it, money's tight), but I'll leave the tig welding to them (with my tig welding skills, it ain't gonna be a clean weld).
Again, thanks a lot! Your replies were incredibly helpful!
18th Aug 2021, 11:49 PM #13Most Valued Member
- Mar 2011
- 1,552
You could lay that up in carbon fibre relatively simply also.
Now knowing the application, you could drop material size down to 0.8 or 1mm if you wanted to, 1.6 is overkill for a container like that.
19th Aug 2021, 12:44 AM #14New Member
- Aug 2021
- Netherlands
- 30
- 4
Carbon fiber would be great, but i suppose the costs would be quite a lot higher.
I initially went with 1.5 mm to mitigate denting the enclosure, also the container is quite long (and it carries a 50kg load).
But you might be right, maybe I should drop it to 1 mm, would save some money and weight. Do you think potential denting won't be too bad with 1mm alu?
19th Aug 2021, 12:55 AM #15
Hi GWalb, Guys,
Depending upon the grade 1 mm aluminium will take some impact to dent it ! Half Hard is tough stuff, but when it comes to bending, you only get one shot at it because it will crack if you try to bend it a second time. It work hardens where the bend is.Best Regards:
How To Design A Sheet Metal Bender?
By abrogard in forum METALWORK GENERALReplies: 17Last Post: 22nd Jul 2018, 08:58 PM -
Mig welding Stainless Steel tube and Sheet
By garfield in forum WELDINGReplies: 20Last Post: 26th May 2016, 09:26 AM -
Douglas Metal Shaper and Bramley Sheet Metal Folder
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 31st Jan 2016, 12:25 PM -
Metal fence design
By Malc in forum METALWORK GENERALReplies: 5Last Post: 1st Aug 2006, 02:10 PM -
Aluminium Metal tube
By brandon26 in forum METALWORK GENERALReplies: 2Last Post: 6th Jun 2006, 09:50 AM
