Results 1 to 15 of 19
Thread: small mill
11th Aug 2021, 08:13 PM #1Intermediate Member
- Aug 2021
- WA
- 25
small mill
Hi all , I am new to the forum , nice to find an Aussie forum , looking forward to it .
I am looking at a new mill , my first one , I was thinking of the Sieg SX4 , but I am tempted to lash out for a knee mill , small Eximus .
I don't know much about milling , but everything I read indicates that you always want a bigger mill .
At this stage I am only thinking of small S/S parts for M/C restoration & workshop tools etc , but who knows from there .
If anyone here has any experience with either of the above , or similar , I would love some feedback .
11th Aug 2021, 08:18 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
I would buy the biggest mill i could to be honest (up to the limit of no bigger than a 40 taper spindle speed is too low on nearly all 50 taper machines. And some 40.)
11th Aug 2021, 08:21 PM #3Intermediate Member
- Aug 2021
- WA
- 25
One other thing .
I have a floor mount pedestal drill , would the mill make it obsolete or will I still need it ?
The reason I ask is that if the drill goes it would be much easier to fit the knee mill in the shed .
11th Aug 2021, 08:23 PM #4Golden Member
- Sep 2009
- 666
small mill
I have an old round column mill and whilst it makes the pillar drill obsolete for big stuff, the small stuff is still easier on the drill.
But if you have to have the space you can still get rid of the drill. Worst case get a small one for a bench somewhere maybe?
I also agree with getting as good a mill as you can. I love mine and it works perfectly for what I need to do but of course, bigger is always better.
I would however advise that an accurate machine would be better than a big machine. My mill is worn out and you can work around it, but it’s harder to get accurate results when you have a lot of slop in the machine.
11th Aug 2021, 08:28 PM #5Intermediate Member
- Aug 2021
- WA
- 25
The plan for the SX4 was to bench mount it , so if I lash out on the knee mill , I can fit a drill on the bench .
A lot more money though .
11th Aug 2021, 08:30 PM #6Golden Member
- Sep 2009
- 666
11th Aug 2021, 08:40 PM #7Intermediate Member
- Aug 2021
- WA
- 25
Not having owned a mill before I have no real plan for it , other than small parts .
S/S is a must for motorcycle parts etc , other than that I will see where it takes me .
I used a mill with an indexer to make a spider for the rear of my lathe spindle but that is the extent of my milling , so I guess I will need room for one of those .
11th Aug 2021, 08:49 PM #8Golden Member
- Sep 2009
- 666
Go as big as you can fit/afford in the shed! I use my lathe and mill all the time. They’re small but more than capable for what I need. With enough accessories and changes in setup, you can make a lot.
11th Aug 2021, 08:54 PM #9Most Valued Member
- Australia east coast
- 2,713
I do a lot of stainless machining. Get as rigid a mill as you can. The small ones will not give you very satisfactory results.
I have a baby Emco FB-2 and 3 bigger knee type machines. The baby mill is quite useful for plastics and aluminium, but I never mill steel or stainless on it if I can help it.
Also you really, really need a power feed at least on the X (long) axis.
PDW
11th Aug 2021, 09:04 PM #10Intermediate Member
- Aug 2021
- WA
- 25
Both the ones I am looking at have power feed on the X axis , but I can only go on the sales pitch for rigidity .
Being in the west , I can't find any on the shop floor other than hare & forbes .
11th Aug 2021, 09:07 PM #11Most Valued Member
- 2,713
Look at the mass of the machines. More is generally better. A lightweight machine will move and vibrate/chatter more than a heavier one, with a big bunch of caveats WRT quality design. Which we're automatically NOT considering when talking about a new consumer-level priced machine from H&F.
PDW
11th Aug 2021, 09:07 PM #12Philomath in training
- 6,541
Bigger is nicer, simily because you have more power at your disposal and they should be a bit more rigid. Model engineers have done amazing work on small machines but why make it harder than it needs to be?
One thing I will add to the advice already given though is that stainless steel is not a nice material to start your milling adventures on. Depending on the grade it can become harder to machine (work hard) if you don't take agressive enough cuts with it. Small machines are limited in their depth of cut by power, so using a small machine, while technically capable, could cause you problems. I would be advising you to start with steel or aluminium and work your way along to S/S once you have an understanding of your mill.
11th Aug 2021, 09:09 PM #13Most Valued Member
- 2,713
11th Aug 2021, 11:57 PM #14Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Just a word of caution on the bigger is better mantra…
Bigger is also heavier, and an order of magnitude more difficult to move. An RF45 size mill is around 350kg, a step up up to a smallish knee mill puts you at around 1200kg.
Don’t get rid of the drill press, as a hobbyist there will be times you will have a setup on the mill for protracted project, sometimes for weeks depending on how much life gets in the way. If you just need to drill a hole in the latest bit of Ikea your Mrs bought home because they forgot to you won’t want to knock down the setup on the mill to fix your other half’s purchasing choices…. The drill press will bare the S on its chest to you at that point.
12th Aug 2021, 12:38 AM #15Most Valued Member
- 5,942
I've had the small X3 mill, it was the biggest POS I've ever come across.
One big bolt at the back to give you the option of doing an angled cut, virtually impossible to keep it in tram, the gears were plastic, I swapped them for metal ones, still had problems, replaced the circuit board a couple of times. It drove me to severe depression, when my brother asked for it back, I would have happily gotten several speeding tickets to get it back to him.
Finally got myself a small mill!
By BobL in forum THE HERCUS AREAReplies: 26Last Post: 12th Jun 2018, 09:17 PM -
Small Horizontel Mill
By TKO in forum METALWORK GENERALReplies: 4Last Post: 6th Apr 2012, 01:44 PM -
Selecting a small Mill / Mill/Drill
By Wombat200 in forum METALWORK GENERALReplies: 31Last Post: 15th Mar 2012, 10:58 PM -
Advice on a small Mill
By Woolant in forum METALWORK GENERALReplies: 8Last Post: 4th Apr 2010, 10:23 AM -
CNC a small X2 hybrid mill
By rodm in forum METALWORK GENERALReplies: 33Last Post: 12th Apr 2007, 03:15 AM
