Results 1 to 5 of 5
    Nov 2019
    Brisbane
    69
    452
    Default Grinding countersink shank and a bit on tools.
    https://www.youtube.com/watch?v=0a7hm9ffA1o&t=3s
    Hello from the old bloke again.
    This tool was made way off center and I was lucky to repair it. What steel gives off sparks like this.
    BC
    Aug 2019
    Revesby - Sydney Australia
    57
    1,195
    It seemed like grinding the shaft was giving off nice long sparks with a final little "firework explosion",
    which I think is Tungsten or Moly' steel?
    What I found interesting is that cutting the face didn't seem to have any branching in the sparks.
    Could have been the video,
    but using a different steel and brazing or friction welding would be a VERY unusual cutter !!!
    Sep 2008
    Riddells Creek, Vic.
    836
    Quote Originally Posted by nigelpearson View Post
    Why would it be a very unusual cutter? It is a common method of reducing costs on materials.
    Aug 2019
    57
    1,195
    Quote Originally Posted by Techo1 View Post
    True.
    For something like this countersink, with a large diameter head (relative to shaft diameter), I would think the force/stress from the cutting faces would make the weld/fusing/brazing too weak.
    It might explain the runout from shaft to head centre, though !
    Nov 2019
    Brisbane
    69
    452
    Default Countersink?
    Hello again.
    The countersink looked to be 1 piece although it is hard to detect if tools are fabricated. I thought the shaft gave off sparks like manganese steel, ground engaging tools. You could induction harden the head and not the shaft so the 2 parts would grind different. Pity the brand name was damaged on the shaft.
    BC
  1. Grinding hex broaches with limited machine tools
    By TommyGMachining in forum Members Videos
    Last Post: 15th Jul 2020, 02:46 PM
  2. Used MT2 shank drill bits or new straight shank
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 28th Jul 2015, 10:06 AM
  3. Advise on grinding metal & tools
    By davidjames in forum METALWORK GENERAL
    Last Post: 28th Mar 2010, 01:42 AM
  4. Countersink
    By Steve in Bell in forum METALWORK GENERAL
    Last Post: 20th Oct 2008, 12:51 PM
  5. Grinding lathe tools
    By Tiger in forum METALWORK GENERAL
    Last Post: 26th Jun 2008, 07:08 PM
