Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Jun 2010
    Canberra
    1,322
    I've not built this but I don't see any reason why it should not work OK .
    That looks to be a unipolar stepper driver. Theses days a driver module for the more common bipolar steppers are crazy cheap to the point where you wouldn't bother making your own. Fore example a dual H-bridge L298N board is $7 off Ebay.
    Would be interested if you can dig up the power supply circuit though.
  2. #17
    6,438
    Quote Originally Posted by RustyArc View Post
    Hi Russell,
    I'm getting a bit out of touch nowadays with steppers and such. Now you mentioning Lm297 and Lm298 chips !
    I have several kicking about but I've never used them. I didn't know what they were until you mentioned the number, so I looked up the data sheet.
    I also found some other info. Unfortunately Not from the same project, but the picture looks similar. As far as the power supply is concerned, it was a linear one fed from a transformer, about 4 amps I think. I actually bought a transformer for this project from a firm in Halifax. I'm fairly sure that I still have it somewhere. It quite big ! It stands about 7 or 8 inches high by about 5 inches square. I'll try and find it and take a picture of it.
    This is the picture of one I found.
    The one that I was looking for had a stepper motor driving a screw, but similar in appearance.
  3. #18
    Jun 2010
    Canberra
    1,322
    I've got tubes of both from my uni days, of which I used very few. The L298 is such a neat chip I was certain I'd find many uses for it.
    Turns out that when you actually look, there's quite a lot about DIY EDM, the simplest looking to use a linear PS and an R-C circuit to generate the sparks.
  4. #19
    Tennant Creek, Aust
    61
    596
    M&G have a 10 piece tap remover set for $20.00
    http://www.mag-pro.com.au/goods.php?id=422
  5. #20
    Jul 2010
    9,088
    Whilst trawling through my backup HDD's I found this picture which is I think part of the EDM drive circuit.
    This help?
    https://www.instructables.com/Easy-t...and-Driver-ci/
    Couldn't find anything on the EDM though
  6. #21
    Jul 2010
    9,088
  7. #22
    Jul 2010
    9,088
  8. #23
    6,438
    Hi Stuart,
    Brilliant detective work, yes those are some of the articles that I remember ! They have been somewhat updated though. Thankyou for finding them and the links. I've re-downloaded them so at least they are now current data.
  1. Broken shaft
    By rumpfy in forum METALWORK GENERAL
    Last Post: 20th Aug 2020, 12:19 AM
  2. Removing broken off spark plugs with oxy torch
    By bob ward in forum METALWORK GENERAL
    Last Post: 25th Jan 2016, 05:48 AM
  3. New Broken Welder
    By MOA in forum WELDING
    Last Post: 7th Nov 2015, 09:28 PM
  4. Broken Tap removal
    By warren in forum METALWORK GENERAL
    Last Post: 8th Apr 2008, 02:35 PM
