Results 1 to 9 of 9
Thread: Help requested sourcing a spring
3rd Aug 2021, 07:49 PM #1Member
- May 2018
- Cairns, Qld.
- 70
Gentlemen... Concerning an older Ryobi BD12 bench drill belonging to a local men's shed;- we have a broken flat coil return spring on the quill; I can't find a replacement (parts no longer available) & the local spring maker in Cairns doesn't have any material that small (7mm x 1mm material, it fits in a 42mm OD housing). Unfortunately the spring has failed right in the middle of it's length, so it's not re-useable).
I've found heavier gauge & size units are available but it's not really feasible to try & fit such a large
item to a smallish drill. Any ideas?
Obviously this doesn't stop the use of the drill, & we have others; one smaller & one larger.
Thanks...
3rd Aug 2021, 08:01 PM #2Most Valued Member
Hi there,
As a last resort could you machine a new housing to fit a larger spring?
3rd Aug 2021, 08:17 PM #3Golden Member
- May 2020
- Willowbank QLD
- 517
Hello
Is it part 28 on this link https://www.toolspareparts.com.au/ry...are-parts.html
If so, always happy to help, if not please disregard.
3rd Aug 2021, 08:19 PM #4Gear expert in training
- 34
- 1,075
Will one of the options here be close enough? https://www.amazon.com.au/uxcell%C2%.../dp/B07LBRYR2F
3rd Aug 2021, 08:21 PM #5Most Valued Member
- 70
- 1,511
Would an 8mm wide spring fit inside cover?
Nev.
3rd Aug 2021, 08:40 PM #6Most Valued Member
- 70
- 1,511
The 40 x 6 x 0.7mm will probably work if you use a 1mm shim.
https://www.amazon.com.au/uxcell%C2%.../dp/B07LBRYR2FNev.
4th Aug 2021, 03:01 PM #7
more
"This Old Tony" on utube has a good video on making springs , he uses piano wire and his lathe.
https://www.youtube.com/watch?v=jAawhg6JtyY
4th Aug 2021, 07:07 PM #8Most Valued Member
- Sep 2010
- Lebrina
- 1,910
While not the most aesthetically pleasing or technical solution, I have seen many a drill press with the spring removed and a cord wound around the shaft that raises a weight when the handle is rotated and simple gravity performs the opposite when the handle is released.
If all other option amount to dead ends, bush mechanics comes to the rescue.
4th Aug 2021, 07:46 PM #9Member
- May 2018
- Cairns, Qld.
- 70
Drill Press Spring
By crikey, you blokes come up with some good leads & ideas! (My prior internet searching was fruitless).
Many thanks to Reidy41 who pointed me straight to an Aussie supplier that I'd not seen before, which hit the jackpot... the part was ordered tonight. Thanks also to the several other members who suggested alternates. I was going to resort to a bungee cord into the shed roof structure if all else failed.
[As I seem to be 'Mr. Fixit' for a lot of stuff that fails at this Men's Shed, repairs can get a bit frustrating at times. The genuine & random minor breakages (as this broken spring) or machine failures are one thing, but what really pisses me off are the unreported faults, where Joe Blow just puts the dust cover on & walks away after breaking something due clumsiness or downright angry use of a machine. This has happened a couple of times. Could be dangerous to other members too.
Sorry... Rant over]
help with spring valve seat manufacture, + steel sourcing S.W. Sydney
By mick21 in forum METALWORK PROJECTSReplies: 10Last Post: 13th Jun 2020, 10:36 PM -
Sourcing set screws
By phaser in forum METALWORK GENERALReplies: 16Last Post: 26th Mar 2019, 01:21 PM -
Sourcing small screws
By kenny_10 in forum METALWORK GENERALReplies: 21Last Post: 6th Aug 2018, 02:47 AM -
Chasing a suitable spring or spring material for a microscope eyepiece clamp.
By Anorak Bob in forum METALWORK GENERALReplies: 35Last Post: 28th Jul 2016, 02:00 AM -
Sourcing Aluminium Hex Rod
By Chris Parks in forum METALWORK GENERALReplies: 8Last Post: 23rd Apr 2013, 10:57 PM
