Results 1 to 7 of 7
    Dec 2009
    134
    Default How do you differentiate Metric/AF blocks etc
    The other day i went through an entire machining cycle without realising that i was using one metric and one imperial 1-2-3 block. Now this was a fairly low accuracy process, so nothing really lost but it got me thinking about my processes, and I realised i probably need a way to differentiate my 1-2-3 blocks and some other tooling from each other.
    One friend has suggested using spraypaint to paint the inside of the block so that it is visually different but the clamping surfaces are still clean. But this probably doesnt work for all of the items.
    What other methods are people using?
    Jun 2007
    Ipswich QLD
    68
    1,996
    Letter No stamp maybe?
    Laser engraver?
    Mark the box they sit in
    Tag them
    Dec 2009
    134
    Laser engraver would work, but i dont have one.
    I would worry about letter stamping something where i would need to have a reference surface, and same goes for tags as they need to be reference surfaces so the tags will inevitably get in the way.
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Hopefully the solution to this 1st world problem does not progress past this post.
    Nov 2017
    Geelong, Australia
    57
    2,651
    If the 123 blocks have threads in them, you could make some plugs out of coloured plastic or 3D print some, or even just put a couple of grub screws in one type to identify them as "different".
    Another way might be to do a swap with someone to get rid of either your metric or imperial ones so you only have one sort.
    Personally - that would be my preference as I find enough ways to screw things up already without adding metric/imperial mixups to the list
    Aug 2011
    4,779
    Measure them with a vernier before use?
    Give one set to me, so you can't get them mixed up?
    Oct 2015
    melbourne
    473
    A bit of sandpaper and polish the larger one until it matches the other.... ��
  1. Interesting vee blocks
    By OxxAndBert in forum METALWORK GENERAL
    Last Post: 29th Jan 2020, 09:23 PM
  2. ER vs 5C collet blocks
    By Pumpkinate in forum METALWORK GENERAL
    Last Post: 4th Feb 2019, 09:13 PM
  3. Jo Blocks
    By YBAF in forum METALWORK GENERAL
    Last Post: 12th Feb 2016, 01:07 PM
  4. How can I touch up V blocks?
    Last Post: 8th Oct 2014, 10:04 PM
  5. 123 blocks and other stuff
    By Woodlee in forum METALWORK GENERAL
    Last Post: 21st Jun 2011, 10:00 AM
