Results 1 to 9 of 9
    Jul 2007
    332
    Default Elite AR5E T&C grinder
    Looking for some photos of the indexable tooth rest for the Elite / Astra AR5E as per outline attached, I need to make one for my machine.
    Any help appreciated. Thanks, Alan.
    near Rockhampton
    6,218
    I googled grinder. Yea those results probably not helpful.
    Dec 2005
    South Australia
    1,658
    Appears to be just a flat flat plate cut/ground/ drilled to fit https://www.youtube.com/watch?v=66ndmrybGjo
    6,477
    Hi Alan, Guys,
    I used my chainsaw sharpener to touch up the teeth on several slitting saws that I have ! I made a support plate With a 1" inch diameter spigot to support the blade and used the saw grinders backstop in the teeth to index the blade as I went round each tooth.
    You can see the plate clamped in the chain guide in these pictures. It is the flat steel plate with the aluminium spigot clamped to it. I used a spring clamp to hold the blade whilst sharpening. The index finger in the first picture is laid back and adjusted with the red knob on the right just behind. The red knob in the second picture adjusts the depth of cut into each tooth. Turning the blade around allows alternate teeth to be angled to suit. I chose 5 degrees for my blades.
    6,477
    Quote Originally Posted by China View Post
    He is using the wrong shape wheel for the tooth profile and has no way of adjusting the tooth edge angle !
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Not sure this will add greatly to the stock of knowledgge, but from a few photos, I got this -
    Sizes on the sketch are based on a dodgy assumption about the width of the slats on the skid, so could be off, but it's all about proportion
    (extra?) pictures below.
    elite-ar5-e-et-tool-cutter-grinder-7795_8_l.jpg elite-ar5-e-et-tool-cutter-grinder-7795_7_l.jpg web-3028_-_oYtrilica_alata_gema-elite_ar5-e-et-metalkovis-9.jpg web-3028_-_oYtrilica_alata_gema-elite_ar5-e-et-metalkovis-10.jpg
    Jul 2007
    332
    Thank you to all for the input, RC not sure abrasive dust would be a good mix for some of the "grinding" undertakings viewable .
    Thanks Michael for the mud map drawing most useful as a starting point, now to get to work. Alan.
    Nov 2019
    Brisbane
    69
    452
    Default tool indexing rest
    Hello Allan.
    If you search for my posts I have posted the pics of a servian indexer the same as you want to copy. I have several and this is the best to use.
    regards
    BC
    Jul 2007
    332
    Hi BC, thanks, trying to track down the post now. Alan
  1. Surface Grinder or T&G Grinder, which is best for adapting?
    By TommyGMachining in forum METALWORK GENERAL
    Last Post: 18th Jun 2019, 09:13 AM
  2. Hercus tool and cutter grinder & cylindrical grinder.
    By stix012 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 23rd Aug 2018, 05:31 PM
  3. Heald internal grinder & Heald Planetary grinder
    By achjimmy in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 11th Oct 2017, 09:22 PM
  4. Smootharc Elite TIG 230 ACDC update, parts
    By blouis79 in forum WELDING
    Last Post: 29th Oct 2013, 01:29 PM
  5. Roller grinder ways/ plain grinder ways
    Last Post: 6th May 2012, 12:37 AM
