Results 16 to 24 of 24
27th Jul 2021, 09:47 AM #16Member: Blue and white apron brigade
27th Jul 2021, 10:51 AM #17Novice
- Jul 2021
- ACT
- 12
Thanks all!
It turns out that I had made a mistake and the shaft is 1", not 1 1/8". It'll certainly be easier to find a 1" drill bit. Whether it'll be clean enough for to fit a shaft without reaming remains to be seen, but at least I won't need a hole saw.
27th Jul 2021, 10:56 AM #18Senior Member
- Feb 2014
- Werribee, Melbourne
- 178
I agree with Michael - unless that handle is a nice snug fit it will be frustrating to fit and use.
If you can get it to Melbourne easier than getting it to riverbuilder by some chance then I would be happy to bore that out for you as well so there is another option for you.
I suspect that the NSW-VIC border won't be easing off for a while but the offer is there.
27th Jul 2021, 11:02 AM #19Novice
- Jul 2021
- ACT
- 12
27th Jul 2021, 11:43 AM #20Member: Blue and white apron brigade
It doesn't matter if it has a pin, if it's a little loose, the pin and pin hole will wear every time you move it and that will eventually put more pressure on the pin so that it may eventually break.
What sort of a drill do you plan to drill the hole with?
27th Jul 2021, 11:47 AM #21Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
To be able to do this properly the person taking on the job will need to have the shaft as well.
27th Jul 2021, 02:00 PM #22Golden Member
- Oct 2001
- ACT
- 667
I understand the Ueee is no longer in the ACT (has moved to bigger premises).
However I am (in ACT), and can bore it out for you, but as Techo1 has said for best results I will need the shaft.
27th Jul 2021, 02:11 PM #23Novice
- Jul 2021
- ACT
- 12
Thanks, everyone!
I'm going to take Riverbuilder up on his offer, as he can supply the handwheels too
27th Jul 2021, 03:54 PM #24Most Valued Member
- 4,258
WTB-Cast Small Cast Iron Lapping Plate
By Betnorm in forum WANTED TO BUYReplies: 4Last Post: 19th Nov 2019, 01:01 PM -
When does cast iron not machine like cas t iron?
By simonl in forum METALWORK GENERALReplies: 20Last Post: 31st Jul 2018, 08:57 PM -
Cast iron english wheel.
By clear out in forum THE FOUNDRYReplies: 23Last Post: 29th Nov 2014, 06:28 AM -
Cast iron fireplace - Question for restoring using Penetrol & Liberon Iron Paste
By mookschank in forum METALWORK GENERALReplies: 8Last Post: 19th Jun 2013, 06:32 PM -
Cast iron VS Cast steel lathe compound slide
By Ueee in forum METALWORK GENERALReplies: 10Last Post: 23rd Dec 2012, 11:40 PM
