Results 1 to 4 of 4
    34
    1,075
    Wink My first fly cut worm wheel
    In the course of my somewhat rushed training to learn literally everything about cutting gears in the space of 2 weeks, a rush custom job came in the door yesterday. Unfortunately, a communication breakdown meant that we weren't told to prioritise training over an insane deadline (boss says "I told the customer he can have them tomorrow", foreman says "are you kidding? we might still be making the tool tomorrow"), so I didn't get to actually make the tool, but at least I got to watch it happen and hopefully absorb some of the principles. The fact that we had an existing tool bit already saved us a couple of hours though.
    This used to be a worm wheel...
    They made up an extra test piece in ally for me to (potentially) stuff up on, fortunately that wasn't the case, then the real ones in aluminium bronze. The drivetrain is set as it would be for a helical gear using differential feed, but, instead of driving the column up the face of the gear, it drives along the cutter axis tangentially to the gear being cut. The tool bit is welded in to the shaft because of size restrictions; on larger worms the bit would simply be held in place with a grub screw
    Finished product looking like a gear again
    Start to finish to set the machine and cut 3 parts took 7 hours and that's not including any of the calculations (add at least another hour) or making the tool (2 hours with the existing bit, 3-4 from scratch), but somehow we still delivered this afternoon as promised. Worms are hard
    Even though I didn't get all the training I would have liked out of this job, if it hadn't rocked up when it did I would probably never have learnt it at all.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Nice work!
    No sniggering in the peanut gallery if this is a really dumb question, but:
    Do you cut one tooth to finished depth then reset back to the start of that tooth, index the blank to the start of the next tooth, then rinse and repeat?
    34
    1,075
    Nope, the cutter spindle and work spindle are linked so each revolution of the cutter cuts one tooth as the work rotates in the same way as normal hobbing. Just have to do multiple passes to get to the proper depth.
    The only time you need to change things around is for multi-start worms where the number of teeth is divisible by the number of starts, then you shift the cutter spindle across by one pitch for successive passes.
    34
    1,075
  1. Machine a worm wheel for my borer.
    By steamloco1954 in forum WANTED TO BUY
    Last Post: 18th Jan 2020, 01:31 PM
  2. need a worm wheel
    By steamloco1954 in forum METALWORK GENERAL
    Last Post: 21st Nov 2019, 05:23 PM
  3. Worm & wheel gears
    By nadroj in forum METALWORK GENERAL
    Last Post: 11th Feb 2019, 10:23 PM
  4. Wrap Aluminium around wooden disc to make a worm wheel
    Last Post: 4th Aug 2017, 12:02 AM
  5. Imperial worm wheel on a metric leadscrew
    By funkychicken in forum METALWORK GENERAL
    Last Post: 6th Jun 2009, 04:33 PM
