Results 1 to 6 of 6
22nd Jul 2021, 12:45 PM #1New Member
- Jul 2021
- Australia
- 2
Angle vs SHS - Which profile for a privacy screen project?
Hello all.
I just purchased a 140 amp arc welder, and some 6013 GP welding rods for my next project in the garden.
Now I am in the process of designing a privacy screen frame. I would appreciate opinions on which metal profile that would be best to construct a 1200 mm x 1200 mm rectangular fame, with 600mm legs concreted into the ground.
My options are using either: 50 x 50 x 4 mm Mild steel angle, OR 40 x 40 x 3mm mild steel SHS.
More concerned about rigidity if using the angle option, it may wobble? Maybe I am overthinking this?
I do understand that angle is prone to torsional forces, however I can't really see such forces being applied holding a 6kg privacy screen (1200x2400mm).
Thanks all.
22nd Jul 2021, 01:13 PM #2Philomath in training
Probably over thinking. How are you going to protect against corrosion? If you hot dip galvanise, open sections (angle etc) are better. If you are painting, SHS probably is a bit less fiddly to paint. With stick welding you can get down reasonably thin with material, so you could probably go under 40x40x3 RHS (maybe 2 or 2.5mm?) Really depends on your welding skills and what you want to do. Maybe start with some trial pieces and see what works best?
22nd Jul 2021, 01:41 PM #3New Member
- Jul 2021
- Australia
- 2
Thanks for the reply, It's been a while since I have welded from trade background but once I practice it will be ok.
I originally planned to use mild steel, I did read that painting gal can be done If I were to use the correct primer, I guess I will be looking at gal RHS as an option now.
Thank mate.
22nd Jul 2021, 05:30 PM #4
Hi Weldhur,
I think that I would be concerned about wind loading with that area !Best Regards:
22nd Jul 2021, 06:19 PM #5
If you use hollow section.
Once u conc it in -- drill some holes just above ground level. Lost count of how many times I have drilled into somones ver posts. Oh look the Trevi fountain!!!
Surprising how much damn water gets into those hollows!Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
23rd Jul 2021, 06:36 AM #6Intermediate Member
- Jul 2021
- Central NSW
- 25
I would upgrade to 50 mm or even 75mm square posts and then use the angle as cross members.
That way the angle will be same size or fit in when butted to the posts. Make posts a tad longer so you can put post caps on them. Depending n the look you are after, you could size it so the screen sits in the top an bottom angle. Paint the bottom 600 of posts in bitumen paint, then just bury or concrete in the ground. If you have a scissor type post hole shovel you can dig a smaller diameter hole which uses less concrete.
PM screen - not quite right.
By Gavin Newman in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 4Last Post: 1st Mar 2019, 06:55 PM -
Does this come up on Your Screen.
By issatree in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 9Last Post: 31st Aug 2012, 12:53 PM -
Full screen/Part screen
By Big Shed in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 39Last Post: 16th Jan 2007, 12:28 AM -
Your Screen Name
By craigb in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 110Last Post: 29th Jun 2005, 10:35 PM
