Results 16 to 20 of 20
19th Jul 2021, 04:38 PM #16Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
I've decided to just cut the post off 100mm and use a longer Stirrup, and move on.
I have already done one of them using the same height stirrup so that one will be the odd one out....no matter. I may replace it with a longer one when all the others are done.
I think I had 'tunnel vision' and was focused on one method and its just too hard. Must be my OCD....lol
Sometimes its a blessing....sometimes it thows you off. I shall reverse back out of this rabbilt hole and go down the new one.
I already bought a couple of spares, so I will take them back and exchange for the longer ones and try again next weeked.
Thanks for all your suggestions guys....I had ran out of ideas and you showed me the way.
Now to work out how to cut 100mm neatly off the bottom of a vertical post.....lol
I'm thinking a 6" circular saw.
19th Jul 2021, 05:34 PM #17Diamond Member
- N.W.Tasmania
- 1,407
One further suggestion would be to remove the post altogether if the top fixings have been better shielded from the weather, and can be removed easily, and take the whole post to a strong (Steel?) bench, preferably with a suitably sized hole and place the stuck bolt over the hole. Strike the projecting bolt end with a sledge hammer and you will most likely shift it. You may have to add an extension to the bolt if you don't have enough protruding, but a 10 or 14lb. sledge hammer will have a fair impact.
A hydraulic press would be another good option. Good luck.
19th Jul 2021, 06:08 PM #18Gear expert in training
- 34
- 1,075
20th Jul 2021, 10:28 AM #19Novice
- Jan 2005
- Sydney Australia
- 77
- 15
20th Jul 2021, 05:44 PM #20Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
Thanks apple8. I originally wanted to keep the stirrups in the same orientation and DIDN'T want to shorten the posts.
I've now decided its too hard to do that and will concentrate on cutting 100mm off all the posts and getting it done.
Found a couple Tube vids on ways to do it neatly.....think I have a handle on it....lol
How to clean rusty bolts
By DSEL74 in forum METALWORK GENERALReplies: 9Last Post: 28th Oct 2018, 10:59 PM -
Best way to remove these sheared bolts
By eskills in forum METALWORK GENERALReplies: 17Last Post: 24th Jun 2016, 11:08 PM -
Upright metal BS stand
By BobL in forum METALWORK GENERALReplies: 8Last Post: 8th May 2015, 08:51 AM -
How Can I Make Bolts Look Rusty
By Ausworkshop in forum METALWORK GENERALReplies: 17Last Post: 30th Oct 2006, 07:15 AM
