Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Oct 2008
    N.W.Tasmania
    1,407
    If gas is going to be burned inside a building and exhaust is not flued or vented it's going to add massive amounts of water to the shed (not to mention loads of CO2).
  2. #17
    Aug 2019
    Revesby - Sydney Australia
    57
    1,195
    Default a year later...
    I still don't have any active ventilation/dehumidifying, or air temperature/humidity logging.
    There was heavy rain & wind on Sunday. New internal factory leak in one spot on Monday. A few days of no rain, so steps/ground under the leak mostly dried out.
    A cold Thursday night (down to 6°), and Friday late morning, DRIP, DRIP, DRIP from the edge of the internal insulation blankets:
    So, exactly one year later, I guess the conditions are identical? At least I got better photos this time.
    I'm going to try, in a few different areas inside;
    1) Shoving something under the blanket, near that edge, so that it is more air-tight above the blanket.
    My hope is that less internal air circulating above the blanket means less condensation on the cold roofing sheet above it.
    2) Duct sealing tape, on the top of the metal, and folded to seal the edge of the blanket to the roofing sheet.
    3) Some thick foam along that exposed edge of roofing sheet, so that it is not available for damp inside air to condense on.
  3. #18
    6,477
    JMTPW, Sprayed foam insulation directly onto the dry metal roofing works much better than a loose insulation blanket, though the adhesive backed stuff works well but is really only suitable for relatively small areas.
    There is a new warehouse being built near me and they are spraying the roof sheets with an expanding foam material. I understand that it is to be a fully automated building with robots doing the running about. I'm only guessing but the word "Amazon" comes to mind !
  1. Greeting fellow metal workers, from Timaru NZ Menz Shed
    By kevlights in forum G'day mate - THE WELCOME WAGON -Introduce yourself
    Last Post: 27th Apr 2016, 11:21 AM
  2. Douglas Metal Shaper and Bramley Sheet Metal Folder
    By bwal74 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 31st Jan 2016, 12:25 PM
  3. Solar panels on metal shed - ideas
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 29th Jul 2014, 08:59 PM
  4. Winter condensation and rust
    Last Post: 11th Jul 2013, 04:28 PM
  5. Condensation problem!
    By Ben Dono in forum METALWORK GENERAL
    Last Post: 28th Jun 2012, 12:41 AM
