Results 16 to 18 of 18
Thread: Condensation in metal shed
25th Jul 2021, 03:51 PM #16Diamond Member
- N.W.Tasmania
- 1,407
9th Jul 2022, 09:31 PM #17Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
a year later...
I still don't have any active ventilation/dehumidifying, or air temperature/humidity logging.
There was heavy rain & wind on Sunday. New internal factory leak in one spot on Monday. A few days of no rain, so steps/ground under the leak mostly dried out.
A cold Thursday night (down to 6°), and Friday late morning, DRIP, DRIP, DRIP from the edge of the internal insulation blankets:
So, exactly one year later, I guess the conditions are identical? At least I got better photos this time.
I'm going to try, in a few different areas inside;
1) Shoving something under the blanket, near that edge, so that it is more air-tight above the blanket.
My hope is that less internal air circulating above the blanket means less condensation on the cold roofing sheet above it.
2) Duct sealing tape, on the top of the metal, and folded to seal the edge of the blanket to the roofing sheet.
3) Some thick foam along that exposed edge of roofing sheet, so that it is not available for damp inside air to condense on.
10th Jul 2022, 05:47 PM #18
JMTPW, Sprayed foam insulation directly onto the dry metal roofing works much better than a loose insulation blanket, though the adhesive backed stuff works well but is really only suitable for relatively small areas.
There is a new warehouse being built near me and they are spraying the roof sheets with an expanding foam material. I understand that it is to be a fully automated building with robots doing the running about. I'm only guessing but the word "Amazon" comes to mind !Best Regards:
Greeting fellow metal workers, from Timaru NZ Menz Shed
By kevlights in forum G'day mate - THE WELCOME WAGON -Introduce yourselfReplies: 2Last Post: 27th Apr 2016, 11:21 AM -
Douglas Metal Shaper and Bramley Sheet Metal Folder
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 31st Jan 2016, 12:25 PM -
Solar panels on metal shed - ideas
By Grahame Collins in forum METALWORK GENERALReplies: 33Last Post: 29th Jul 2014, 08:59 PM -
Winter condensation and rust
By morrisman in forum METALWORK GENERALReplies: 27Last Post: 11th Jul 2013, 04:28 PM -
Condensation problem!
By Ben Dono in forum METALWORK GENERALReplies: 25Last Post: 28th Jun 2012, 12:41 AM
