Results 1 to 5 of 5
Thread: 1/3/8. 4 TPI ACME Leadscrew
11th Jul 2021, 07:05 PM #1New Member
- Apr 2011
- Queensland
- 3
Hi All,
I was wondering if anyone could recommend a source in Australia for leadscrews. I want to replace the worn out lead screw on my old Macson.
It's a 1/3/8 - 4 RH. I haven't been able to fund anywhere in Aus that sells them that big.
Thanks in advance
11th Jul 2021, 07:23 PM #2Philomath in training
- 6,540
I know McMaster over in the US have them (in either 3 or 6ft lengths). Someone like Shipito might be able to do an assisted purchase for you but the freight will add several $100 to the price I would think. I doubt you will find that size easily in Oz as the place has been metric for around 45 years...
Plan B might be to get someone to make one for you. How long does it need to be?
12th Jul 2021, 08:40 AM #3
Hi VonChipflinger
Please post in the appropriate MetalWork forum. General discussion and Off Topic sub forum is for exactly that- Off topic, non metalwork subject posts.
This post is moved to MetalWork general.
Please understand that down the track those searching through MetalWork forums posts will have an easier time of it ,if the post being searched for is related to the forum it is posted in.
As far as a leadscrew for a 60 or 70 year old lathe, I suspect one shall have to be made for you.
12th Jul 2021, 06:29 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
Do you have a pic of your leadscrew? i have seen a lot of worn out lathes but never one with a worn out leadscrew.
17th Jul 2021, 05:35 PM #5Most Valued Member
- Australia east coast
- 2,713
Only seen one myself but that was a leadscrew on a smallish lathe that was also used for power feed via the half nuts (no keyway). I made a replacement and after doing that I'd not do it again.
IMO the USA is the place to go for this as there are a number of companies that do acme threaded rods & nuts in various grades of precision. But it will cost.
Alternative, see if you can get someone to run one off on a CNC lathe for the acme threaded section and do the ends etc yourself. Should be a pretty easy programming job really. Might need to be re-set once or more for travel length/stiffness but that's do-able. Not by me though.
PDW - now stuck in Sydney for the foreseeable future...
Leadscrew
By Petip in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 22nd Apr 2017, 08:38 AM -
Where can I buy Affordable Acme Threaded Lead Screw & Flanged Acme Threaded Nuts
By RoyG in forum METALWORK GENERALReplies: 8Last Post: 1st Sep 2014, 12:26 PM -
3/8-12 acme tap
By rusel in forum METALWORK GENERALReplies: 5Last Post: 23rd Mar 2012, 02:39 PM -
ACME 1/2 - 8 LH rod available ?
By morrisman in forum METALWORK GENERALReplies: 32Last Post: 1st Dec 2011, 10:22 AM
