Results 1 to 9 of 9
    Jan 2007
    somewhere on the northern beaches
    6
    Default Steelfast bandsaw lubrication
    Hi I have a steelfast bandsaw and I was wondering what is the correct lubrication to use for the bearing on the top wheel (first picture) and for the bush on the cone pulley (second and third), it looks like it has had grease in it, but I would have thought that oil should be used is this correct?
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    In that situation I would have said grease as oil would run out.
    Jul 2007
    332
    Based on the photos alone I suspect that grease would be used, but they appear to be sealed, if so, would not require further lubrication unless there is something else on the shaft. I will look at my saw tomorrow. Alan
    6,475
    At first glance I too would have said oil ! The bearing probably only has a seal/shield on one side, so a light grease.
    Often the bearing manufacturer will specify grease for low speed running and oil for higher speeds.
    Jul 2006
    Athelstone, SA 5076
    4,258
    Cheapest insurance would be to replace with sealed bearings.
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by L8N View Post
    I have played with a couple of these whoever said replace the bearings in the top wheel with sealed ones is spot on. The other lubrication point is for the back gear mechanism and that should be the same oil as you put in the gearbox because that is where it ends up. You only need to lubricate it when you are using the back gear as it doesn't rotate unless you do.
    Jul 2007
    332
    Have checked my Steelfast bandsaw and all visible bearings appear sealed units. Alan
    Jan 2007
    6
    Thanks for the replies everyone. I will end up replacing the top bearing with a sealed unit down the track.
    C-47 Your bandsaw appears to be a later version than mine.
    Quote Originally Posted by lamestllama View Post
    I was thinking that it would be similar to the back gears on my Hercus lathe, only needing to be oiled when used.
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by C-47 View Post
    That's because you have a Steelfast 370 the original poster has a 14" Steelfast.
    I am currently reviving a Steelfast 370 and they are very refined in comparison to the 14". There is one unsealed bearing on the 370 model. But its a thrust bearing.
  1. Steelfast die filer on gumtree in Sunbury Victoria
    By L8N in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 8th Sep 2019, 06:13 PM
  2. Steelfast Bandsaw original electric motor size
    By paul33 in forum ELECTRICALS
    Last Post: 14th May 2019, 12:29 PM
  3. woodfast / steelfast vertical bandsaw
    By monchochos in forum METALWORK GENERAL
    Last Post: 20th Mar 2019, 07:43 PM
  4. 14" Steelfast/Woodfast Bandsaw
    By lamestllama in forum METALWORK GENERAL
    Last Post: 27th Dec 2018, 07:59 PM
  5. SteelFast Bandsaw
    By Petip in forum METALWORK GENERAL
    Last Post: 18th Jun 2014, 01:43 PM
