Results 1 to 4 of 4
2nd Jun 2021, 08:27 PM #1Intermediate Member
- Jun 2021
- worldwideweb
- 27
undercutter / bed lifter - how thick and which steel to use?
Hello everyone!
I am planning to build an undercutter/bed lifter tractor attachment. The goal is to slide a slanted board 10-12inch (25-30cm) deep into the ground and lift the soil just enough, so that you don't need to use a shovel to dig out root crops such as garlic or carrots. This is how it looks in action:https://www.youtube.com/watch?v=xAZrUAG3PcE . And a lighter version: https://www.youtube.com/watch?v=OrFVcQOJlB0
These are my dimensions:
https://ibb.co/QYWYbfN(top link arm isn't drawn)
https://ibb.co/q1zYDPw
I am unable to asses how thick should the sidewalls and the bottom lifting board be and which steel is best suited for such applications. Can you help me out? Does anyone have an undercutter on the farm and would be willing to measure how thick the steel is? The one in the video looks 3/4" to 1", not sure what type though.
So my choice is between regular steel and hardened steel. I believe regular steel is marked as S355 or S235, the number 355 and 235 corresponding to the yield strength in MPa of the steel. Yield strength is determined under axial stretching of the specimen and corresponds to the maximal Force per area under which elastic deformation occurs. Hardened steel has yield strength 3-5 times higher than the regular steel. For example AR400 or Hardox 450 steels have yield strength 1187MPa and 1250MPa respectively(https://www.steelwarehouse.com/ar400/ and https://www.ssab.com/Products/Brands...cts/Hardox-450)
Is yield strength directly proportional to how much the steel would resist bending in transverse direction too (as opposed to axial streching)? Because it is nuts to think that 1/4" AR400 would resist more to bending than 3/4" S355 structural steel. Am I reading this numbers correctly?
Thank you for taking your time and answering this question!
3rd Jun 2021, 10:47 AM #2Diamond Member
- Jun 2010
- Canberra
- 1,322
This one: https://www.tilmor.com/en-us/products/260/undercutters says it uses 1/2" x 4" cutting edge. The sides look a bit thicker though - maybe 3/4".
No idea about what steel to use. If I only had mild steel available, I'd probably hard face the cutting edge and the faces of the sides with a welder.
5th Jun 2021, 09:28 PM #3
First up
Hi Potato
welcome to the MetalWork Forums
We have some fine folks here who are supportive friendly and helpful.
Please take the time to navigate around the forums to view the varied and interesting subjects.
To do this, goto the the FORUM box in the top left hand corner of the screen. Click Forum Home and a scroll down page will come up.
Scroll down the page and the various help pages and sub forums shall be shown.
Please read the Terms of Use on the very top of the scroll down page - they are our rules.
To save time heres the link
https://metalworkforums.com/f90/t197...terms-tou-read
Many pages also have a sticky at the top.If you post its always a good idea to check the sticky ,if there is one there.
Please post your questions in the appropriate MetalWork forum.
Again, welcome to our forums.
Not all ground engagement tools need hardfacing.
Factors you might consider are : It looks sandy loam
Draw bar Horsepoer of the tractor
The abrasiveness of the soil.
The frequency of use or amount of acres/hectares worked.
Hobby farm or commercial will dictate what you can spend on it ,I guess.
Note the steel grade used in the American sample was 1060 grade -Not sure what that converts to for European steel classication.
Note! it is not haedfaced. It looks similar to your design- why re invent the wheel if you may not need to. Is the tractor power comparable. Maybe all the decisions are not hard to make after all.
Your dimensions seem heavy and I would consider holding off hardfacing until you give the unit a small test run.
Measure thickness and weight from new and compare both after a fixed amount of work.That will tell you if the plate is wearing excessively for a short run. Do a small amount and multiply it out to give a expected wear rate for a total hectare-age for your growing season.
At that point you may or may not wish to hardface dependent on you calcs.
Certainly use low hydrogen electrodes or wire to weld it.
Hardfacing is expensive and toxic as well. It may work out cheaper to run with the 1060.
Again welcome to our forums
Moderator
5th Jun 2021, 10:08 PM #4Diamond Member
- Jun 2010
- Canberra
- 1,322
Hydraulic Lifter Mod.
By SurfinNev in forum METALWORK PROJECTSReplies: 4Last Post: 26th Oct 2020, 07:06 PM -
Chasing steel plate approx 900 x 600 x 10-15mm thick
By aarggh in forum WANTED TO BUYReplies: 0Last Post: 1st Oct 2020, 01:32 PM -
gridmesh pieces in Perth? and thick sheet steel?
By desbromilow in forum WANTED TO BUYReplies: 4Last Post: 2nd Aug 2017, 05:34 PM -
welding thick steel sections
By markgray in forum WELDINGReplies: 14Last Post: 6th Jun 2016, 07:23 PM -
welding very thick heavy duty steel??
By Mathuranatha in forum WELDINGReplies: 6Last Post: 21st Jun 2008, 09:28 AM
