Results 1 to 15 of 15
Thread: How to blacken steel
31st May 2021, 02:48 AM #1
31st May 2021, 11:33 AM #2Member: Blue and white apron brigade
I've tried this method (in the kitchen oven) and it does indeed work and looks real nice, but it did generate some smoke so if you have an outside BBQ oven suggest using that instead of an oven. Also you can general fit larger pieces in a BBQ oven.
As someone who runs dust/particle detectors inside a house 24/7 teven though it may not look that bad he huge volumes of sub micron particles generated by heating wax and linseed oil to 425F (220șC) in a domestic oven is pretty scary. If you do this make sure you have really good ventilation, not just a standard stove top range which are pretty useless at ventilating the amount of fine (invisible) particles produced. The stuff will fill your house and takes hours to dissipate. Mind you the same applies to any general high heat oven cooking or using gas appliances that are not well ventilated.
It won't look black or perhaps as smooth but plain linseed oil will provide plenty of protection. Start by leaving the object in the sun on a hot (30șC+) day for a couple of hours and then paint on the linseed, if it's too thick add a (little) bit of turps. Leave it to dry under a hot sun. It may take as long as a week to develop a fully hard surface. On rusted objects the rust can be passivated with something like tannic acid (Fertan) or other passivator. I like using tannic acid because it passivates to black.
Here's a before and after of a BS vice I scored from the men's shed.
Under the blue paint was deep layers of rust, mostly removed with a wire wheel on an angle grinder and the remainder passivated with tannic acid, then coated in linseed oil and left in the sun,
31st May 2021, 01:28 PM #3Senior Member
- Feb 2012
- Tamworth, NSW
- 205
Here is a spoon I forged last Saturday and gave it some beeswax from our hive (I did not refine the wax in any way so it had a fair few impurities from the hive in it). Seems to give it a nice finish. I rubbed the beeswax on the hot steel - it was too hot to hold but tried to apply at the point where it had cooled enough not to smoke when you apply the wax. Buffed it off with a rag while still hot.
31st May 2021, 06:26 PM #4Member: Blue and white apron brigade
That looks pretty good to me and was one of the ways the instructor at the blacksmiths course I attended blackened got us to blacken the tools we made. The other method was dunking into a light mineral oil but mine came out pretty scaly although it was probably too hot before dunking.
31st May 2021, 06:50 PM #5Golden Member
- May 2020
- Willowbank QLD
- 535
Does this blackening method that heats the steel to 425f effect the properties of the steel.
For example, if I had a motorcycle axle made out of 4140 and used this method would I likely reduce the strength.
Or if I took a grade 5 bolt and used this method, would I be asking for trouble.
Now for the disclaimer, if someone tells me it will cause no issues and I try it, I acknowledge I am trying at my own risk and will not hold them in any way responsible. I don't like this new world where it is always someone else's fault.
31st May 2021, 06:53 PM #6Gear expert in training
- 34
- 1,079
31st May 2021, 07:14 PM #7Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
That would depend on the type of material, most high tensile steels start to reduce in hardness, and therefore Tensile Strength, at temperatures above 200 degrees C with hardness reducing further as the temperature increases. There could also be the possibility of Hydrogen Embrittlement with High Tensile Steels.
31st May 2021, 07:18 PM #8Most Valued Member
For that application, why risk it? Here's what you need: https://www.claytonfirearms.com.au/p..._category_id=0
31st May 2021, 08:00 PM #9Gear expert in training
- 34
- 1,079
Huh...would have thought 200C was nothing for steel
31st May 2021, 08:10 PM #10Member: Blue and white apron brigade
It depends on the size of the object but most fully hardened heat treatable steels will lose between 2 and 5 points of RC hardness at around 220șC
BUT
I also doubt 220șC will do much tempering in 20 minutes, my experience it it takes about an hour for knife size pieces at these temps.
Besides I don't see these methods as intended for protection of hardened steel.
Perhaps more importantly is how accurate are domestic ovens at ever reaching an actual temperature and holding it. My testing shows they're not that good. The ones I've tested were all over the place.
[EDIT] I just found my tempering guide and the general rule of thumb is a one hour tempering soak per inch of thickness, BUT with a minimum of two hours is recommended for any size piece.
Liquid quenched steels may be tempered in one pass, but air quenched require multiple tempering cycles, and cooled to about 100șC between cycles.
31st May 2021, 08:19 PM #11Golden Member
- May 2020
- Willowbank QLD
- 535
Well, the purpose of the question was to see if I am risking anything. I happen to have a very large block of bees wax and a bottle of linseed oil. If I asked a general question, such as does this effect steel, I would probably get a general answer.
I am becoming more educated now and can make a decision based on some logic as to if I would use this method.
The other reason for considering using a product like this is that I am finding some of the older simpler ways worked well. They just get lost in time.
1st Jun 2021, 02:20 AM #12
Can of black paint works every time
1st Jun 2021, 07:15 PM #13Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
Take it to the electroplate place
1st Jun 2021, 08:16 PM #14Gear expert in training
- 34
- 1,079
2nd Jun 2021, 12:04 AM #15Diamond Member
- N.W.Tasmania
- 1,407
I was unaware that Hydrogen embrittlement was a possibility when heating iron or steel, in fact I thought that heating steel parts which had been electroplated for example would drive off any Hydrogen which had been absorbed into the crystal lattice structure of the steel part. Have I been mistake in my belief?
Loan of a Steel hoop or piece of steel with a hole about 350 mm in diameter
By BobL in forum METALWORK GENERALReplies: 13Last Post: 17th May 2018, 08:04 PM -
mild steel to stainless steel
By cava in forum WELDINGReplies: 8Last Post: 27th Nov 2014, 06:48 AM -
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
best steel
By eskimo in forum METALWORK GENERALReplies: 15Last Post: 7th Jun 2012, 10:33 PM -
Help me ID some steel
By 19brendan81 in forum METALWORK GENERALReplies: 4Last Post: 12th Apr 2012, 08:09 PM
