Results 1 to 5 of 5
    Jul 2008
    near Warragul, Victoria
    3,726
    Default Camel back dilemma
    I have a old camel back drill, think it's a American Barnes but not sure, It has the four selectable power feeds which is nice. . The base casting for the C/pulley mount is broken , the break about four inches long . I have the broken piece . I am wondering about repair options ? Bronze brazing would require a lot of heat . There are two slotted rails in the base - maybe I could make up a heavy plate and bolt it to the slots and then mount the C/pulley and motor on the plate ?
    Edit: i Just remembered this one I have is a Rockford, which was a company affiliated with Barnes. This particular model I have, has geared power feeds which I have not seen on any other Camel back, they normally use a small flat belt system for the power feed
    Camelback Drills
    This one is similar to mine
    1909 Rockford Drilling Machine
    Conversion to V belt
    https://talk.newagtalk.com/forums/th...ed&setCookie=1
    Nov 2008
    Ballarat
    37
    I’ve welded cast iron before on a few occasions but it’s not what I’d call easy.
    The main precautions are similar to other welding tasks. That is to get everything super clean beforehand and ensure that the components are securely held in alignment while welding.
    There are different grades of cast of course and your filler or electrode choice needs to be appropriate to the base material.
    After separating the broken components, with something that size I’d heat the whole part to just under red hot before welding. We used a furnace for the heating and sat the work on heatproof ceramic. The amount of radiant heat can be fairly fierce so you need to fully suit up.
    It needs planning because you really don’t want the work to cool down. I map out my movements beforehand and have a couple of helpers on hand. With bigger pieces I weld the central portion first and then return to the heat before continuing to weld laterally. This prevents skewing due to differential contraction when the welded section cools. Some bigger jobs have taken half a dozen reheats.
    I return the completed work to the furnace and bring the whole piece up to just under red heat and then slowly drop the temperature back down before wrapping in a piece of old upholstery leather filled with old leather gloves. We keep old leather welding, gardening and riggers gloves in a crate just for this job. The package is left overnight to very slowly come back down to room temperature. It isn’t completely foolproof but saves the great majority of cracking.
    Feb 2013
    Laidley, SE Qld
    1,039
    If that were mine I'd be thinking of fabricating a new steel base in the style of a casting.
    Oct 2015
    melbourne
    473
    Repair to use or restore to original?
    Maybe a new large baseplate either square or cut to shape and bolt the pieces to that.
    Would tig silicon bronze work? Less heat and localised.
    Jul 2010
    9,088
    This guy managed a successful stick weld repair.
    https://www.youtube.com/watch?v=0Ako5guyzNg
    Camel backs quiet?(your first link) mine sure isn't, straight cut bevel gears cant help.
  1. 6' Camel Back Straight Edge
    Last Post: 17th Aug 2017, 02:24 PM
  2. When is a camel back straight edge too big?
    By simonl in forum METALWORK GENERAL
    Last Post: 19th Jul 2017, 09:39 AM
  3. Camel Back query
    Last Post: 28th Jan 2012, 01:14 AM
  4. Web site for Camel Back Drills
    Last Post: 23rd Dec 2011, 12:12 AM
  5. Camel back
    By Lanza_1 in forum METALWORK GENERAL
    Last Post: 5th Aug 2009, 06:09 PM
