Results 16 to 21 of 21
Thread: Drill Press Table
30th May 2021, 10:54 PM #16Golden Member
- Jun 2005
- Helensburgh
- 618
Mine sits on the arm as yours does, I don't see that as a problem at all, just changing the size of the spigot will organise that. What is more important is the length of the arm from the centre of the spigot to the column and I suspect that mine has less distance in that dimension than more modern drills but I have never compared any. I think I am pushing water uphill with a fork to tell the truth but never ask and you never get. I don't want to modify the original table and putting another one on would enable me to add a tilt adjustment to it at the same time which would be useful. Making one is possible for not much money at all but if I find one already made that is easier. I have been thinking about this off and on since I bought this DP so 40 years ago so I thought I would ask the question and see what falls out of the woodwork so to speak.
CHRIS
31st May 2021, 09:01 AM #17Member: Blue and white apron brigade
31st May 2021, 10:55 AM #18Golden Member
- Jun 2005
- Helensburgh
- 618
31st May 2021, 11:04 AM #19Member: Blue and white apron brigade
If you can't find one, given you're going to add a significant X-Y table and then a extra slotted table on top of that, the weight is then going to be very significant. In that case what about just replacing the existing cast iron table with something made out of Al plate eg 16 mm thick should be OK - weld a spigot on one side to connect to the arm and bold the X-Y table to the top.
31st May 2021, 12:24 PM #20Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
I was in Carbatec earlier this morning, the DP1500 dill press they had on display had a decent size rectangular table with T slots. Might be able to purchase the table as a spare part from them.
https://www.carbatec.com.au/pedestal...-code-dp-4132f
31st May 2021, 12:30 PM #21Golden Member
- Jun 2005
- Helensburgh
- 618
Drill Press Table Refurbishment ( Or A Recipe For Disaster? )
By Anorak Bob in forum METALWORK GENERALReplies: 33Last Post: 30th Jul 2019, 04:50 PM -
Waldown Drill Press Table
By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 27th Sep 2018, 06:51 PM -
Drill press hold down table
By BobL in forum METALWORK GENERALReplies: 23Last Post: 2nd Sep 2018, 10:00 AM -
Waldown drill press table question
By DSEL74 in forum METALWORK GENERALReplies: 9Last Post: 2nd May 2016, 04:19 PM -
Tough Drill Press RPM Table?
By Burnsy in forum METALWORK GENERALReplies: 3Last Post: 13th Aug 2014, 08:29 PM
