Results 1 to 6 of 6
Thread: Raw Steel Finish
29th May 2021, 09:00 PM #1New Member
- 8
Raw Steel Finish
I'm planning a bookshelf using 25x25 steel and timber (see links if interested). I still haven't decided which design but the look is what's most important to me.
Option 1 - https://a360.co/39Yzd1X
Option 2 - https://a360.co/3vw9iYd
My usual supplier has blue painted steel but I'm wanting an raw finish that's not shiny - Like the picture I've attached. Does anyone know if you can buy steel that hasn't been painted or galvanised in Melbourne or is this a job for a wire wheel on the grinder?
29th May 2021, 09:28 PM #2I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
https://melbournesteelsales.com.au/s...i-bright-6-1m/
https://robotbuildingsupplies.com.au...t-square-tube/
https://handysteel.com.au/erw-tube-semi-bright-square
Probably plenty of others around. The first one is likely to be one of the cheapest around if you're out that way.
29th May 2021, 09:33 PM #3New Member
- 8
Thankyou! That's the term I was missing. That'll make the search easier.
29th May 2021, 10:39 PM #4Most Valued Member
30th May 2021, 12:30 AM #5Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
Oven cleaner will strip the blue paint and leave the matte finish like your picture.
Soda blasting will also
I’d look at upping the size of the steel on the corner posts in your design. 25 SHS will bow or twist if you’re a real bookworm and fill that with books. It also looks anemic in tall designs like book shelves. I generally don’t spec less than 40SHS for tall applications like that.
30th May 2021, 01:56 AM #6New Member
- 8
Are you planning to apply a coating? It will rust eventually, even inside.
Yes, I'm going to apply a clear spray coat over the steel.
It's not going to be full of books. Aa few display things as well. Thanks for the advice though.
surface finish
By TED C in forum METALWORK GENERALReplies: 9Last Post: 7th Aug 2015, 07:48 AM -
What finish is that?
By neksmerj in forum METALWORK GENERALReplies: 1Last Post: 24th May 2015, 09:18 PM -
Supplier of high speed steel and tool steel bar and spring steel in melbourne?
By fudo133 in forum METALWORK GENERALReplies: 3Last Post: 25th Jun 2014, 12:44 PM -
Threads on finishing, finish, good finish
By steamingbill in forum METALWORK GENERALReplies: 17Last Post: 20th Jan 2014, 06:53 PM -
Finish on steel?
By Schtoo in forum METALWORK GENERALReplies: 7Last Post: 23rd Jun 2005, 10:33 PM
