Results 1 to 8 of 8
Thread: Mill Quill DRO !
25th May 2021, 09:03 PM #1
Mill Quill DRO !
My BF20LB mill has a digital readout on the quill, since I fitted the three axis DRO I've discovered that the quill readout sticks and the readings change in jumps ! I had never noticed before but it annoys me now. The slide is moved when ever the quill is raised or lowered by a rather poor long piece of plastic bar screwed between the slide and the quill.
I've circled the bit that pulls the sliding bar up and down. Please excuse the rather wobbly red brush lines .
On close examination I've found that the bar that runs through the readout head is twisted by the plastic bar and it also pushes the bar to one side making the slide stick in the guides. I've come to the conclusion that this is not good for either the readout or its repeatability.
So in order to rectify this problem and also to provide an attachment point for another gauge I intend to make a replacement as per the drawing below.
This is a simple clamp made from 10 mm thick hard aluminium plate, clamped directly onto the quill with a single M4 cap screw at the back. The long wide piece at the front will be used to move the quill DRO slide. Hopefully it won't have any flex worth bothering about and can also be used to carry a clock gauge or other instrument.Best Regards:
26th May 2021, 09:19 PM #2
Mine never came with one, so for the DRO I made a steel collar, welded to a shaped plate with a triangular support then to a 20x20mm vertical post that holds the reader head. It was a bugger to get it to totally run accurate to the quill, but has worked fine all these years since around 2009.
The multipurpose dial indicator arms connected to the triangular support thread, makes traming the vice and jobs easy and quick as it's there ready to go.
Sent from my 5007U using TapatalkUsing Tapatalk
26th May 2021, 11:55 PM #3
Hi Dave, Guys,
I suspect that you might be a little ahead of me there ! I've already started to make the clamp plate ! I will post some pictures later on.Best Regards:
27th May 2021, 12:19 AM #4
27th May 2021, 12:23 AM #5
I've actually been thinking lately to have an enclosed cover to make it look like it was enclosed and part of the mill head like your type of mill, but with a Bridgeport style downfeed stop.
I originally had a aluminium cover on it.
27th May 2021, 10:31 PM #6Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
This is how I did it on a Beaver Milling Machine, it is not very elegant but certainly is handy to use.
30th May 2021, 06:57 PM #7
I only just remembered about a picture of mine when taking pictures of my electric drawbar build progress for Bollie this afternoon sorry.
30th May 2021, 06:58 PM #8
Another
Drilling on a mill without a quill
By OxxAndBert in forum METALWORK GENERALReplies: 11Last Post: 18th Jan 2019, 09:48 PM -
Handle of the cva quill.
By welder in forum METALWORK GENERALReplies: 0Last Post: 22nd Mar 2017, 05:02 PM -
Custom Quill
By DaveTTC in forum METALWORK GENERALReplies: 16Last Post: 11th Apr 2014, 06:47 PM -
HM 52 quill slot
By Dave J in forum METALWORK GENERALReplies: 15Last Post: 6th Jan 2013, 04:28 PM -
DRO for the quill
By simonl in forum METALWORK GENERALReplies: 10Last Post: 2nd Feb 2012, 06:03 PM
