Results 31 to 45 of 67
Thread: Helical gear maker?
25th May 2021, 11:11 PM #31Most Valued Member
- 5,942
Nice looking bike, what year is it??
25th May 2021, 11:12 PM #32Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Another photo shows the more usual type of brake, which has one lever on the brake plate.
Mine has two levers with a linking rod, which is an obstruction that requires the speedo cable to exit at a greater angle.
That needs to have the different helix angle on the driven gear.
25th May 2021, 11:14 PM #33Mechanical Butcher
- Oct 2004
- 1,894
25th May 2021, 11:22 PM #34Mechanical Butcher
- Oct 2004
- 1,894
25th May 2021, 11:34 PM #35Mechanical Butcher
- Oct 2004
- 1,894
It's a 350, almost identical to look at.
I used to think the Ducati 50cc pullrod 4 stroke bicycle motor was the ultimate of its type, until I learnt about the Bugatti effort.
It has twin overhead camshafts and is supercharged, about 10cc.
the Bugatti revue, 12-1, Bugatti T72 fact sheet and photos
26th May 2021, 12:30 AM #36Golden Member
- Apr 2019
- 589
If you are not a genius on CAD I am sure there are some smart cookies on this site who could draw it up. There will almost certainly be some locals who can nylon print. I would try my 3D printer for you but so far I have not managed to get decent and accurate enough prints yet.
26th May 2021, 07:32 AM #37Philomath in training
- 6,541
Gears when used as skew gears rub a bit - not sure a 3D printed one would last long. The helix angle is the critical bit. Once we know that, the maths can leap into effect and it will probably work out.
26th May 2021, 08:35 AM #38Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
26th May 2021, 10:24 AM #39Most Valued Member
- 4,255
26th May 2021, 11:21 AM #40Golden Member
- Apr 2019
- 589
Nad, I have just done a quick google for "speedometer nylon gear" and there are plenty of cheap alternatives. If I was you I would be working out the overall gear ratio you need then finding a pair of gears pre-made - it them doesn't matter what the MOD or helical angle is just as long as the 2 match each other. You might need to modify them slightly to fit your shafts.
26th May 2021, 11:26 AM #41Gear expert in training
- 34
- 1,075
26th May 2021, 11:34 AM #42Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
Toyota G52 etc series gearbox. Right angle speedo drive out of the side of the box, nylon gear is 23.5 OD x 14 long.
26th May 2021, 12:00 PM #43Most Valued Member
- Healesville
- 2,129
I think all of the cars that i worked on in the 70's & 80's had a plastic gear on the mainshaft and a plastic gear on the speedo cable, the gears in on the speedo cable were color coded and slightly differant diameters, i was a mechanic in the police workshops and we would drive a car over a measured kilometer and take note of the odometer reading and then fit the right coloured gear to get the odometer calibrated to the spec it needed to be.
Then the speedo/needle spring would be adjusted/calibrated by using a machine that drove the speedo, the machine had a calibrated speedo and you used that to set the other.
I dont recall ever seeing a plastic gear on any motorcycle that i have worked on
26th May 2021, 12:54 PM #44Golden Member
- Apr 2019
- 589
26th May 2021, 01:02 PM #45Mechanical Butcher
- Oct 2004
- 1,894
video: cutting helical gears
By StrayAlien in forum METALWORK GENERALReplies: 8Last Post: 12th May 2020, 11:32 AM -
Cutting helical gears
By Michael G in forum METALWORK GENERALReplies: 12Last Post: 1st Apr 2015, 10:12 AM -
Helical gear confusion
By Ueee in forum METALWORK GENERALReplies: 4Last Post: 10th Apr 2012, 01:10 PM -
Helical milling
By Michael G in forum METALWORK GENERALReplies: 1Last Post: 21st Oct 2011, 01:37 PM
