Results 1 to 15 of 67
Thread: Helical gear maker?
25th May 2021, 09:20 AM #1Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
Helical gear maker?
I want a small helical gear to fit a speedometer drive gearbox on a motorbike.
Is there some place that does this work?
It probably needs to be hardened too.
25th May 2021, 02:42 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
What size are we talking here? Getting a one off small gear may not be easy.
25th May 2021, 03:02 PM #3Golden Member
- Apr 2019
- 596
You could try Hercus. Bought bevelled gears from them but not sure if they have helical.
25th May 2021, 03:57 PM #4Mechanical Butcher
- Oct 2004
- 1,898
A big company could charge a hefty price.
Someone with an horizontal mill with a geared dividing head setup could do it.
I don't have such. I'd be happy to talk to anyone who could take it on as a job.
The OD of the gear is about 12mm.
https://www.youtube.com/watch?v=0I_wJLsDo-U
25th May 2021, 06:43 PM #5Philomath in training
Aw gee fellas. You could have at least linked to the home grown version...
https://www.youtube.com/watch?v=5TJ6sn-oGgk
If I had the specs I could probably do something.
25th May 2021, 06:54 PM #6Most Valued Member
- Jul 2016
- 35
- 1,522
The person who takes it on will need to know the tooth count and dp/module of the gear. Unless you find someone extremely generous id start looking for spares.
If ungettable, and it really needs to be hardened id start piling up the shekels.
25th May 2021, 08:52 PM #7Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Pretty cool helical gear cutting video, thanks for the link.
Does anyone know who the highly intelligent, skilled, and patient gentleman is?
25th May 2021, 09:05 PM #8Mechanical Butcher
- Oct 2004
- 1,898
25th May 2021, 09:13 PM #9Gear expert in training
- 34
- 1,080
We'd need the tooth count, pressure angle, helix angle, OD and bore size. Pics would be helpful too. The helix might be tricky to measure accurately on something that small without a comparator though, ideally you'd provide the original to whoever is doing the job.
I reckon I could do it at work after hours, the only issue would be finding a window when we have a free hobbing machine so I can't guarantee it will happen soon.
EDIT: To answer your question about price, by the time you've taken measurements, calculated the differential ratio, turned blanks, set the machine and cut the gear, you're looking at a few hours work; the hobbing itself might only take 5 minutes, but there's all the other stuff that has to happen before you get to that stage. At a nominal shop rate of $120-150/hr it gets very expensive to make 1 of something.
25th May 2021, 09:13 PM #10Mechanical Butcher
- Oct 2004
- 1,898
25th May 2021, 09:25 PM #11Mechanical Butcher
- Oct 2004
- 1,898
25th May 2021, 09:40 PM #12Philomath in training
25th May 2021, 09:42 PM #13Mechanical Butcher
- Oct 2004
- 1,898
Right, now I'm getting an idea of the cost. It's not justifiable, sadly.
There's no real market for this gear so no chance to amortise the cost with some sales to others.
Thank you and others for the info though.
If I can trouble people with some more questions:
- I don't have a universal mill. Is one really necessary for helical cutting, or is there a workaround using a plain horizontal mill?
- Can any dividing head be geared to a mill's leadscrew?
- Anything special about the gears between mill and div. head, or is any arrangement that can supply the required ratio OK?
25th May 2021, 09:42 PM #14Gear expert in training
- 34
- 1,080
Does it have any shoulders or other features, or is it just a flat gear with a hole in the middle? I'll also need the bore size before I commit to any price because if we don't have an appropriate hobbing arbor I'd have to make one and that will add to the time needed. It's very likely that we do have one amongst the probably hundreds in the cupboard, but just in case it's a weird size...
Not sure about hardening, but I could use 4140 which should be strong enough as is or I might be able to sneak it in with a batch of nitriding.
EDIT: The shop rate I mentioned was if you were to walk in the door at an engineering firm, I wouldn't be asking anywhere near that as a private jobGear cutting specialists and general engineers www.hardmanbros.com.au
25th May 2021, 09:44 PM #15Golden Member
- Apr 2019
- 596
Could you 3d print this part?
Could you find a suitable gear in a bike or car wreckers?
video: cutting helical gears
By StrayAlien in forum METALWORK GENERALReplies: 8Last Post: 12th May 2020, 11:32 AM -
Cutting helical gears
By Michael G in forum METALWORK GENERALReplies: 12Last Post: 1st Apr 2015, 10:12 AM -
Helical gear confusion
By Ueee in forum METALWORK GENERALReplies: 4Last Post: 10th Apr 2012, 01:10 PM -
Helical milling
By Michael G in forum METALWORK GENERALReplies: 1Last Post: 21st Oct 2011, 01:37 PM
