Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 67
  1. #31
    Nov 2007
    melbourne australia
    3,228
    Assuming its unloaded output is 12V, I'd say you've overloaded it and the output has dropped. If you connect only one LED does it consume 5W?
  2. #32
    7,189
    Are you using the power pack that's supplied in the base of the lamp or something else?
  3. #33
    Feb 2012
    Tamworth, NSW
    205
    Quote Originally Posted by Chris Parks View Post
    Chris, did you do a thread on your VFD drill press install?
    Ian
  4. #34
    Sep 2006
    Australind , WA
    58
    1,281
    Yes, I thought that would happen. Will do some more checks on weekend.
    Will try running lights in series as well.
  5. #35
    Sep 2006
    Australind , WA
    58
    1,281
    Small supplied plug pack. Want to try and get away with only using ONE of them, due to space requirements. More tests to do.
  6. #36
    7,189
    Quote Originally Posted by Sterob View Post
    So, trying to drive two lamps from the one pack - I expect that will have something to do with what you are experiencing.
  7. #37
    Sep 2006
    Australind , WA
    58
    1,281
    Yes, it wasn't a surprise. You have to try theses things, don't you.
  8. #38
    Sep 2006
    Australind , WA
    58
    1,281
    Got 5 minutes today to test the setup with the lamps in series.
    Light output seems good and was still getting 275 mA. Think I'll go with that.
    https://photos.app.goo.gl/jXkp9w6x9JHivXsL6
    Next is to get it all mounted and usei t!
  9. #39
    7,189
    Are you sure you have your "series" and 'parallel" right.
    Depending on the grunt of the power pack, two devices in series will usually draw half the current compared to when they are in parallel.
  10. #40
    Nov 2007
    melbourne australia
    3,228
    Unless the parallel devices were overloading the power supply causing it to enter overload protection. But confused terminology is certainly a possibility too.
  11. #41
    Sep 2006
    Australind , WA
    58
    1,281
    Wink
    Yes, I have 'series' and 'parallel' terminolgy right.
    LEDs are current driven devices, so running them in series means the same current goes through both LEDS.
    It appears that this setup works fine. The brightness of both lamps are the same and at a good level.
    I still have 275 mA drawn from the plug pack, I am not overloading the plugpack. If the voltage is high enough to forward bias both leds, then we are golden.
    I suspect that if there was a problem the plug pack would get very warm in a short space of time. Its does not.
    I think the job is done and I'm very happy with it.
    All that reamins to do is to use over a long term, and see if anything arises.
    https://photos.app.goo.gl/QqgT32mn2d7uTRLP7
    https://photos.app.goo.gl/bUyyKeCnptxG7rxq6
    Sorry Chris....I didn't want a shadow....
  12. #42
    Nov 2007
    melbourne australia
    3,228
    You’re probably right. But you aren’t getting 5W from each LED either. I think you said the power supply was 20V? If so, that’s 10V across each LED and 2.75W power dissipation per LED. But if you’re happy with the lumens, you’re sweet.
  13. #43
    6,475
    Some of these electronic power supplies are designed to current limit ! That is the voltage varies whilst the current is limited to a set value. The only way that you can test that is by measuring the DC output current into a single load, then doubling the load and measuring the current to see if its doubled as expected !
    There are some very clever LED driver chips around, particularly for automobile lighting.
  14. #44
    May 2021
    Sunshine Coast QLD
    62
    My drill. My friends idea. Works a treat.
    (Selfie light from Amazon)
  15. #45
    7,189
    Quote Originally Posted by skypig View Post
    NOICE! How many watts/lumens?
  1. Looking for a Drill Press
    By Bobelix in forum METALWORK GENERAL
    Last Post: 6th Dec 2020, 07:02 PM
  2. What did I buy, Drill Press
    By Reidy41 in forum METALWORK GENERAL
    Last Post: 22nd Aug 2020, 11:37 AM
  3. Paper drill from converted drill press
    Last Post: 16th Mar 2020, 07:26 PM
  4. Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
    By bwal74 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 10th Feb 2019, 03:11 PM
