Results 1 to 12 of 12
Thread: Meyers Sensetive Drill
20th May 2021, 09:34 AM #1
I’d love to 3D print a template of the badge so I could cut it on the Pantograph.
As found condition. This thing doesn’t appear to have done any work in its over 100yr life. Not a single mark on the table etc and the planner marks still visible. The base was on backwards.
After rejuvenation. Currently sitting in the lounge room much to my partners disgust, as I don’t have a safe space for it in the shed where it won’t get knocked about.
D02ACCBC-46E1-4512-912B-814D46824593.jpeg…..Live a Quiet Life & Work with your Hands
20th May 2021, 02:05 PM #2China
- Dec 2005
- South Australia
- 1,658
Looks like a nice little machine, what actually runs it does it have a separate motor mounted somewhere
20th May 2021, 02:06 PM #3
There is a loose & tight pulley with a shift on the bottom cone pulley. That would take another flat belt to a line shaft.
20th May 2021, 04:49 PM #4Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,554
Those after shots are machinery p@rn if ever I saw it...
Enough said
20th May 2021, 04:57 PM #5Gear expert in training
- 34
- 1,080
20th May 2021, 08:24 PM #6
20th May 2021, 08:26 PM #7Gear expert in training
- 34
- 1,080
Oooh I thought you had one and wanted to redo it.
20th May 2021, 10:12 PM #8Most Valued Member
- Mar 2011
- 1,554
Looks flat, you could probably have that routed on a CNC machine
21st May 2021, 07:16 PM #9Philomath in training
It's close - haven't got a font that is an exact match for 'MYERS' though
23rd May 2021, 10:09 AM #10
5th Mar 2022, 05:32 PM #11
Even though it was done ages ago, I thought some of you may like to see the finished badge.
Michael G did a great job of creating the file for me which I 3D printed and used as a template to cut on my Alexander 2C pantograph, I then formed the slightly tapered curve on the swage block and filed it with paint, polished and clear coated.…..Live a Quiet Life & Work with your Hands
5th Mar 2022, 09:02 PM #12Most Valued Member
Michael to the rescue again. Thanks Michael
Paper drill from converted drill press
By bollie7 in forum METALWORK GENERALReplies: 4Last Post: 16th Mar 2020, 07:26 PM -
Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 10th Feb 2019, 03:11 PM -
5/8 ths drill.
By BaronJ in forum METALWORK GENERALReplies: 11Last Post: 3rd Nov 2016, 03:26 PM -
Drill Point Drill
By Penpal in forum METALWORK GENERALReplies: 11Last Post: 18th Jan 2007, 10:22 AM
