Results 1 to 9 of 9
    May 2021
    UK
    51
    2
    Default Reomving corrosion from rowing machine paddles in a sealed tank
    Hi there. I've got a slightly tricky problem here - due to my own idiocy for not making sure to use the correct item, I used a chlorine tablet as a water purifier in the tank of my Water Rower, and it has corroded the stainless steel paddles inside the tank. They sat in the chlorinated water for a week or two, until I actually noticed the water going brown (!) and drained it as best I could. The tank is sealed and only has a 30mm hole in the top for draining the tank (using a hand pump or whatever). The corrosion looks bad, but it doesn't look like it's actually compromised the strength or structure of the paddles, so seemingly it's only cosmetic.
    What I'm after, then, is a product that can be put in the tank and help dissolve the rust/clean the metal, but without any scrubbing, because I can't open the tank to actually get to the paddles. I can operate the paddles, so they can move around in the solution, though. The tank is plastic and really well sealed. Even if I could remove the seal, it would make the tank look terrible and I wouldn't be able to reseal it properly. Also, there's a lot of wooden structure around the tank that is a complete pig to get off. I've tried it before.
    So if such a product exists, it needs to be safe on the plastic, and I need a lot of it - I need to fill the tank up enough to cover the paddles, which is at least 15-20 litres. I've seen things like white vinegar suggested, but I can't help thinking that might not be strong enough to really get the corrosion off if I'm not able to scrub it.
    Thanks in advance for any suggestions.
    Cheers.
    Dec 2005
    South Australia
    1,658
    Chlorine should not affect the correct stainless steal, commercial swimming pools use stainless steel for that very reason, I am not a scientist but I would try something like bicarb (sodium Bicarbonate) to neutralise the chlorine then flush the the whole tank and replace the water.
    May 2021
    UK
    51
    2
    Quote Originally Posted by China View Post
    Thanks for the reply, but the problem is that whatever the paddles are made of, they have been corroded by the chorine - maybe it's not chlorine resistant stainless steel, because the water purifier they recommend isn't chlorine-based, I used the wrong thing. I've also drained the tank, so the chlorinated water is not a problem now, all I want to do is try and remove some or all of the brown corrosion from the actual metal, just to make it look better really.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    This forum is mainly Australians so the names might be different in the UK, but have you tried something like CLR?
    Filling the whole tank is probably not an option, but either sloshing some around in there, turning the tank so it is in contact with the main surfaces or diluting it down may work.
    Oct 2004
    Southern Highlands NSW
    1,898
    Steel wool and elbow grease?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Quote Originally Posted by nadroj View Post
    Did you read the 1st post?
    7,189
    We've got something similar so I know what you mean about access
    First thing is to get hold of a small water feature pump because you are going to have to get loads of water in and out of the tank.
    I would try some vinegar - ideally you would fill teh tanks but that's going to cost a few bob so just get 4L of vinegar and move the paddles around every few minutes and repeat that until the corrosion is dissolved. then remove the vinegar
    fill tank with water and slosh paddles around a bit - repeat that at least twice.
    Fill tank with water and use proper sterilising tablet for the machine.
    Oct 2015
    melbourne
    473
    Ah, transparent tank. Now I understand. I'm thinking more like staining than corrosion. If vinegar doesn't work, or CLR (Calcium lime rust remover), maybe evaporust. Options getting dearer, but your machine is not cheap either.
    Maybe talk to a stainless fabricator. I know there are specialist products for cleaning stainless, no idea if they can be applied inside a tank.
    6,480
    Its quite likely that even if the paddles are stainless, the shafts may not be !
    The parts had to be assembled and put into the tank, so I think that making it a completely sealed unit is a rubbish idea ! Making this item un-maintanable is one way of limiting its life !
  1. Stop Corrosion
    By 1voyager2 in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 13th Aug 2019, 09:42 PM
  2. Stop Corrosion
    By 1voyager2 in forum METALWORK GENERAL
    Last Post: 2nd Aug 2019, 07:14 PM
  3. Drilling and tapping into a sealed vessel
    By bosco555 in forum METALWORK GENERAL
    Last Post: 30th Nov 2017, 05:00 PM
  4. Corrosion on Stainless Steel
    By Karsty in forum METALWORK GENERAL
    Last Post: 3rd Nov 2016, 11:28 AM
  5. Replies: 4
    Last Post: 1st Jul 2013, 09:12 PM
