Results 1 to 4 of 4
Thread: Greenlee Knockouts
19th May 2021, 12:43 PM #1New Member
- May 2021
- Cleveland
- 50
- 1
Greenlee Knockouts
I have .125” aluminum plate, which I guess works out to about 8.5 gauge. I had in mind to buy Greenlee Kockouts, but these are rated for 10 gauge “mild steel” plate. My question whether l would get away with using these on the 8.5 gauge aluminum since (I am under the impression) that aluminum is softer than mild steel. Am I wrong about that? Am I stuck using stepper bits?
judd
19th May 2021, 06:14 PM #2
G'day Havemaj@icloud
Welcome to the MetalWork Forum. You landed amongst a bunch of Aussies though we have members from all over the world.
I remember Greenlee punches as our sheetmetal bloke had a set. As for the rest you have to wait until someone who has used them comes along.
A great bunch here very helpful and supportive of one another.
If you explore our pages you will find bits and pieces of interesting things all over the place.
Go to the FORUM at top LH corner and click on it.
A drop down menu appears and you can select Forum Home at the top of the drop down. Scan down the pages to look at what we have.
Please read the Terms of Use -our Rules - pretty standard for many forums these days.By joining the forum its automatic that they apply to you as a member
Normally the soft ware works so you can't post pics or links until 10 posts are made ( or such links and pics are cleared by a mod)
Its an anti spam thing.
If any questions contact me via PM and I'll try to help you.
19th May 2021, 07:29 PM #3Philomath in training
Provided that the sheet is not a high strength alloy, it's probably worth a try. As a rule of thumb I use when working sheet, if equipment is good for a given thickness of steel, it can manage half that in stainless and twice that in Al.
If they are the sort of punches that I'm thinking of it may come down to the driving force of the arm behind the spanner...
22nd May 2021, 11:38 AM #4Senior Member
- Apr 2018
- 168
If its this style of punches, manual or hydraulic, they will handle 0.125mm ally easily. Use a step drill to position the pilot hole, more accurate than drilling a normal 8mm hole.
As a electrician I'de hate to think how many holes i've made using these type of hole punches in steel, ally and stainless steel enclosures.
Always use a decent cutting fluid, i found Wurth to work well and dont rush it by forcing the punch through. Also a couple of extra washers under the hex head and lubricated works well.
They always give a better finish compared to using holesaws.
