Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    May 2007
    Sth Gippsland Vic
    130
    Default Is there a place where 1/2" x 1" HSS tool blanks can be bought ?
    1/2" x 1" x 4" long or 8 " long would be good .
    Rob
    May 2007
    Sth Gippsland Vic
    130
    I just found some on Ebay in the USA .
    I have looked there before ( A number of times) but found nothing that size.
    Rob
    May 2007
    Sth Gippsland Vic
    130
    Hopefully its OK stuff . Anyone seen or used it before ?
    Should be good if it is US stuff.
    https://www.ebay.com.au/itm/38339125...oAAOSwBsleLZFP
    May 2011
    Murray Bridge S Aust.
    5,956
    Found this on flea bay about $80 au. from the states inc postage. https://www.ebay.com.au/itm/38339125...oAAOSwBsleLZFP
    HTH
    May 2007
    Sth Gippsland Vic
    130
    Thanks Kryn.
    We both went and did the same thing after I posted .
    I think Ive searched at least 6 times on Ebay for such sizes over the last year. A few times in the US .
    I want to make some cutting tools for my Wadkin RS tool carriage . I have one that came with the lathe, second in from left .
    Its for woodwork but there is some metal work Id like to try on it as well. With the correct types of grinding for such work.
    Here's some pics of the type of tools and the holder.
    Mar 2011
    Southern Flinders Ranges
    1,552
    I may some, I’ll check and report back, they may have already been moved along in the great purge of 2020
    Apr 2012
    Healesville
    2,129
    https://www.voestalpine.com/highperf...h-speed-steel/
    I think this mob has a minimum charge of $150 now....
    May 2019
    Picnic Point, Sydney
    77
    314
    Why not weld or braze a HSS piece to some MS flat bar?
    May 2007
    Sth Gippsland Vic
    130
    Quote Originally Posted by Snapey View Post
    I did think of that but welding HSS doesn't work . Ive done it a number of times and it did stay on one piece once but mostly it just falls off with the slightest pressure.
    So in another experiment I brazed it . HSS to lengthen spoke shave blades . The heat ruined the cutting edge . I suppose the only way is to braze and keep the cutting end cooler .
    I'd still need the 1/2" x 1" size to do that just less of it .
    I did buy some of those US HSS Ebay pieces .
    Apr 2012
    Healesville
    2,129
    What did you use to weld the HSS?
    I have used 2.5mm 316L stainless rods successfully a number of times.
    May 2007
    Sth Gippsland Vic
    130
    Great . Something I may try out thanks .
    I used my Mig welder with the standard welding wire. After a fail I tried one weld by heating to red hot then welding and leaving to cool slowly buried in covered saw dust with a lid . Still failed .
    There's one I did before all this that held for some reason ? The later regular fails were ebay Chinese HSS used in some wood turning chisels I made.
    One fell into two pieces the first try at wood turning , placed it to cut wood and the slightest pressure the welded join fell apart like I had joined it with spit . I ended up finding a brass tube and did a ram fit with hammer on anvil to join it to some mild rod that lengthened it for placement in the wooden handle .
    Apr 2012
    Healesville
    2,129
    I welded this bit of hss onto a truck axle to get into a deep hole in cast iron, pic taken after the boring job.
    Apr 2012
    Healesville
    2,129
    Not 100% sure but I think these (from BOC these days) https://www.cigweld.com.au/product/c...ft-2-5-3-2-mm/ were used at a place that i worked a loooong time ago for welding HSS, they might work better than the 316L rods, you might also be able to get them in one of those handy packs of 5 or 10 rods and also pick the brains of the sales guy he might have a something more suitable.
    Mar 2014
    South of Adelaide
    1,227
    Have only ever used 316 rods to weld HSS never had any issues.
  15. #15
    Mar 2011
    1,552
    Reporting back, I only have some small pieces of 3/8x3/4 in rectangular, no 1/2x1
  1. Permanent Place To Post "Educational" Information ?
    By dogboy in forum METALWORK GENERAL
    Last Post: 16th Jun 2017, 04:01 PM
  2. Internals of "Tree" boring tool revisited attemp 2
    By WoodBee2 in forum METALWORK GENERAL
    Last Post: 14th Nov 2015, 09:05 AM
  3. Expiration Date in "MARKET PLACE/AUCTIONS My Activity" Shows The Wrong Date
    By RoyG in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 27th Sep 2014, 01:11 AM
  4. New Thread Title to Replace "today's tool gloat"
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 7th Jun 2014, 03:58 PM
  5. A "make Lemonade" moment (I bought a lemon)
    Last Post: 8th Aug 2013, 06:24 PM
