Results 1 to 5 of 5
Thread: The SC4 Tailstock is horrible!
11th May 2021, 07:03 AM #1New Member
- Feb 2021
- Lincolnshire
- 53
- 9
Hi there, I have a question about the Sieg SC4 and variants. If this is in the wrong forum please have me severely flogged and point me in the right direction...
The tailstock is woeful, it seems accurate enough but unless you push the thing down heavily with every movement chips and muck get underneath. I've adjusted the slide and locking washers under the stock so I 'just have' slide when unlocked, but it makes little difference, any tighter and it grabs.
So, does anyone have this lathe and found a better solution, a tailstock from a different machine, a 3rd party option?
Over to you folks.
Many thanks.
11th May 2021, 07:38 AM #2Philomath in training
Have you considered a felt wiper on the front of the TS so that the chips can't get in?
11th May 2021, 05:23 PM #3
Hi Scruntfundle, Guys,
Didn't we go through this problem a short time ago !
I recall that you were asked to check if the clamp plate was flat and did it slide on a machined surface, I don't recall if you made any reply.Best Regards:
11th May 2021, 09:26 PM #4Most Valued Member
12th May 2021, 12:30 AM #5
Hi Chris,
That is exactly what I thought !Best Regards:
Help with tailstock
By Briangoldcoast in forum METALWORK GENERALReplies: 7Last Post: 23rd Oct 2018, 11:01 PM -
I think it needs a new tailstock
By Burner in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 31st Jul 2014, 11:56 PM -
Tailstock Shimming
By Anorak Bob in forum METALWORK GENERALReplies: 62Last Post: 16th Aug 2012, 04:27 PM -
Tailstock and Bed
By Auskart in forum THE HERCUS AREAReplies: 7Last Post: 12th Aug 2012, 10:01 AM -
Tailstock DRO
By Stustoys in forum METALWORK GENERALReplies: 58Last Post: 11th May 2011, 01:15 PM
