Results 1 to 11 of 11
    Jul 2008
    near Warragul, Victoria
    3,718
    Default Split point drill grinding
    What are your favoured methods to grind the tips of the grind split point twist drills ? I've seen where some use a dremel and a small wheel.
    Nov 2019
    Brisbane
    69
    452
    Default split point drill grinding
    Hello Morrisman.
    It is a lot easier to web thin the drill off hand. A good 6" bench grinder and an A80 wheel, dressed flat and a small radius is all you need. For split pointing it is better with a V jig to lay the drill in and pass under a tool and cutter wheel as accuracy is important.
    We need a tool grinding forum.
    BC
    6,439
    Hi Morrisman, Guys,
    Built this drill grinder/sharpener ! There is a picture of mine right at the bottom of the page.
    https://www.gadgetbuilder.com/DrillSharp.html#Facet4
    I t works very well indeed ! I have only found one very small issue with sharpening a drill. Whilst you will get an almost perfect four facet point, when you come to use a drill that has a bend in it the hole is always oversize. It is not a fault of the grinder but you often cannot see the slight bend in a drill without clocking it !
    Nov 2019
    Brisbane
    69
    452
    Default drill web thinning
    Hello again. The first pics show my approach to the wheel. Moving the shank of the drill left or right changes the rake angle, or flute angle of the drill. You only need to take off 1-2mm. If you grind the whole edge out to the diameter to 0 deg the drill is Dubbed for brass and perspex. Rotating the drill a few degrees anti clockwise takes most of the edge away from the wheel and you only modify the drill near the web. Bring the drill edge up to the wheel and push the drill tip inwards till the drill is thinned at the web. Rotate and do the other side. The last pic shows a thinned web. All common drills 4mm and over in size come with wide web design. Take a few drills and practise, you will pick it up fast.
    BC
    Jul 2008
    3,718
    Default Thanks
    Hi BC
    Yes, that web thinning you described and pictured is what I do as a normal part of the sharpening process.
    Nov 2019
    Brisbane
    69
    452
    Default splitting drill points
    Hi Morrisman and all in general.
    I have shown these before but missread the request on this post.
    The first pic shows point splitting a 1/2" drill. With a bit of fiddling you can get the drill point to pass under the wheel and there is no need for travel stops. I have left off the indexing arm for clarity. The Clarkson table cross feed and wheel height adjustment makes for an accurate job.
    The last 2 pics have a shop made attachment that will split points on drills up to 2 1/2" after which I run out of room under the wheel. With the sub plate on the table my work envelope is more than doubled. By rotating the big drill against the brass button the lip can be positioned where you want, then the stop brought up behind the shank to secure it. This set up gives good control when dubbing drills for brass or other point work for difficult to drill work. If you don't have a T & C grinder make up an angle iron slide running inside angle iron.
    Sorry to take so long I have had to work for a few days.
    BC
    Jul 2008
    3,718
    Nov 2019
    Brisbane
    69
    452
    SAM_0773.jpgHello Morrisman.
    I'm more familiar with practical application texts. The Yanks are open with tech info and prices are OK too.
    BC
    May 2021
    Surrey
    14
    Default Mystery part
    Thanks for posting the first picture. When I acquired my Simonnet DZ450 lathe, it came with all sots of goodies, one item I had no idea as to function. After all this time it’s the drill holder from a Clarkson tool grinder. I now need to see what I’m missing to create a functional tool grinder.
    Quote Originally Posted by steamloco1954 View Post
    BC
    Oct 2010
    melbourne, laverton
    1,910
    Is there a movie?
    UOTE=morrisman;1984565]Have a few hours to s
    p
    are ?
    http://unsworks.unsw.edu.au/fapi/dat...CE02?view=true[/QUOTE]
    Jul 2008
    3,718
    Default more
    This is a good article I think
    http://neme-s.org/2005%20May%20Meeting/drills.pdf
  1. Big drill grinder with point splitting.
    By steamloco1954 in forum METALWORK GENERAL
    Last Post: 2nd Feb 2020, 09:35 PM
  2. Cutter grinding split point drills
    Last Post: 2nd Jan 2020, 12:16 PM
  3. Cutter grinder indexing for split point drills
    Last Post: 1st Jan 2020, 01:40 PM
  4. Saber split point drill sets
    Last Post: 19th May 2018, 01:34 PM
  5. Drill point geometry 2
    By markgray in forum METALWORK GENERAL
    Last Post: 9th Mar 2017, 11:14 AM
