Results 1 to 6 of 6
1st May 2021, 08:41 PM #1Most Valued Member
- 70
- 1,511
Machining hubs and tyres for a pallet lifter
I have a 1000kg capacity pallet lifter similar to the pic posted here. When I finally get my lathe set up the first job I need to do is make four new hubs and tyres for it. Originals were butchered by previous owner. These are the guide rollers for the mast. Going to do hubs first. Plan is to machine the threaded end of all four first, then use this end screwed into a holder machined and left mounted in the chuck to do the bearing ends. I am thinking they will all be more accurate for bearing fit and alignment this way. Is that correct or is there a better way? There's an internal bore to be done as well for the small adjustable side guides and rollers on the bearing end. As a guide to size these take a 45 x 85 x 19 bearing.
Nev.
1st May 2021, 08:44 PM #2Most Valued Member
- 70
- 1,511
A couple of poor pics of hub. Will try to upload clearer images another time.
Nev.
1st May 2021, 09:28 PM #3
I'd be holding it by the shoulder, not the thread's
Sent from my 5007U using TapatalkUsing Tapatalk
1st May 2021, 09:31 PM #4Most Valued Member
- 4,887
Seems a logical and easy way of doing it, is the section behind the thread too small to hold.
1st May 2021, 09:42 PM #5Most Valued Member
- 70
- 1,511
1st May 2021, 10:37 PM #6Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
I would do all the operations on the left side first, then flip it over and cut the threaded side, then mill the flats. I’ve also been known to do things backwards too
Small Tyres
By Goggomobile in forum AUTO RESTORATIONReplies: 10Last Post: 14th Nov 2015, 01:40 AM -
Electric Pallet lifter
By BobL in forum METALWORK GENERALReplies: 19Last Post: 29th Nov 2014, 06:22 PM -
Rims and Tyres
By Big Shed in forum TRAILERS & OTHER FABRICATED STUFFReplies: 0Last Post: 10th Dec 2012, 01:17 PM -
Drilling hubs question ?
By Gristle in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 31st Oct 2011, 01:13 PM -
Changing hubs
By waky53 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 28th Sep 2008, 01:06 AM
