Results 16 to 28 of 28
Thread: Availability of 50x50x2 angle
30th Apr 2021, 11:10 PM #16Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
I can bend 900 lengths of 1.6 if that’s of any use to you
1st May 2021, 01:14 PM #17
China,
I called into my steel bloke yesterday after some angle in various sizes and was told there is a "shortage" of certain sizes currently in OZ.....he told me that he has difficulty getting enough of the thinner sizes but plenty of thicker.
I was after 3mm stuff but had to end up with 5mm as could not wait and he wasn't sure when his orders would be met or the quality he eventually got. It's a production matter with supply he said so they are importing stuff and taking what is available - here's the issue where a lot of it is rubbish but all that's available. You can guess where that's coming from!
He's a pretty big local supplier and not a small fry by any means and I get all my welding supplies from him too......I've had some rods on back order with him for well over 6 months now and he's not alone there. Mind you I can get cheaper rods if I get stuck but I prefer to buy quality and spend less time cussing
That may be your answer with supply..????
1st May 2021, 02:44 PM #18Most Valued Member
- Mar 2011
- 1,555
Or it’s time to find a supplier that is actually interested in your business...
1st May 2021, 04:27 PM #19China
- Dec 2005
- South Australia
- 1,658
No it is not a supply issue it is no longer produced.
1st May 2021, 06:13 PM #20Most Valued Member
- Mar 2011
- 1,555
I was referring to rods being back ordered for 6months and a supplier up selling 5mm angle because he’s overstocked and giving you the ‘Bat stew virus supply issue’ line.
1st May 2021, 06:27 PM #21Most Valued Member
The forum's quote function can save a lot of confusion.
1st May 2021, 07:56 PM #22Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
There is defiantly a steel supply issue. I'm having trouble sourcing some round bar sizes, and some hot rolled products for work, we spend a lot of $$$ a month so i doubt we are getting stuffed around.
2nd May 2021, 04:41 PM #23Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Can definitely confirm major supply issues. Be advised to not expect any improvement this year.
2nd May 2021, 05:30 PM #24Most Valued Member
- Mar 2011
- 1,555
Interesting. I work for Australia’s largest supplier of iron ore, production didn’t slow during COVID restrictions, it actually increased. Autonomous haulage in the Pilbara has been a massive game changer for every site that has adopted it, with all the major players heading down that path. One can only assume there is a massive pile of dirt from the Pilbara sitting on a dock somewhere in Asia.
3rd May 2021, 12:22 PM #25Most Valued Member
- Sep 2010
- Lebrina
- 1,915
It puzzles me too. the explanation I've been given is increased demand coupled with decreased production from the steel mills. Why the steel mills have decreased production, I couldn't say. I have been unable to get 25X25X1.6 Gal SHS since the second last week of February this year. Initially I was able to substitute 25X25X2 Gal, but that ran out by the time I needed another 25 lengths in late March and as of last week, the 1.6 still hasn't arrived in stock, but I was able to grab some more 2mm. Many bread and butter flat bar sizes are out of stock, but 50mm+ RHS and SHS aren't too badly affected thus far it seems.
Some imported steel is supplementing local production, but overall, it's not too rosy and we just need to wait it seems.
3rd May 2021, 01:28 PM #26Most Valued Member
- 4,258
3rd May 2021, 04:20 PM #27Most Valued Member
- Sep 2010
- Lebrina
- 1,915
3rd May 2021, 06:30 PM #28Most Valued Member
- Healesville
- 2,129
Its going to be a bit harder for the producers to make steel if they can't put some commonsense on the table in regards to the BS C02 caper..
BHP 'sets new bar' with carbon cuts targeting steel mills, shippers https://www.smh.com.au/business/comp...10-p55ua3.html
China struggles to rein in steel production https://www.ft.com/content/c74c3674-...a-95d8c8f796db
Interesting, steel from hydrogen https://thenarwhal.ca/steel-coal-mining-hydrogen/
Availability of 7/8 X 14 UNF round stock--
By Briangoldcoast in forum METALWORK GENERALReplies: 20Last Post: 15th Apr 2019, 08:09 AM -
L00 backplate availability
By morrisman in forum METALWORK GENERALReplies: 1Last Post: 24th Jul 2018, 08:28 PM -
Pre-holed or Pre-drilled angle iron or steel/alloy availability?
By seanlark in forum METALWORK GENERALReplies: 11Last Post: 1st Aug 2013, 01:29 AM -
Melbourne - Availability Of Steel Metal Plate
By Metal Head in forum METALWORK GENERALReplies: 2Last Post: 15th Jan 2009, 08:38 PM -
Metal availability
By MathewA in forum METALWORK GENERALReplies: 12Last Post: 16th May 2005, 05:02 AM
