Results 1 to 15 of 22
25th Apr 2021, 08:27 PM #1
Opinions on DRO display side for a milling machine
Something I've thought about for many years but done nothing about is the factory installed side of a DRO display on the right.
I'm just about to make up a full control panel with a DRO built into it, VFD control buttons for both vertical and horizontal spindles along with RPM displays, main power etc.
In the next week or 2 I'm going to change the DRO to the left side for a trial, as I seem to be always looking over my right shoulder to view it using the quill, and stretching to see it when using the knee.
The E stop will be located on the knee, so it will always be in the same easy to reach spot.
What have others done over the years?
It seems every mill sold today is on the right, where every lathe sold is on the left, which I'm comfortable with.
Years ago I did try my lathe with the readout mounted to the carriage but didn't like it as it seemed awkward and was in direct line for chips etc.
Dave J
Sent from my 5007U using TapatalkUsing Tapatalk
25th Apr 2021, 09:33 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
I put mine on the left because on a smaller machine like the RF45 I have it’s away from the quill handles
25th Apr 2021, 09:38 PM #3Philomath in training
- 6,562
Mine is on the left too, as that is the side you stand to operate the feed levers etc.
25th Apr 2021, 09:40 PM #4
Thanks to you both, pretty much confirms my thoughts.
25th Apr 2021, 09:54 PM #5
25th Apr 2021, 10:01 PM #6Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
25th Apr 2021, 10:28 PM #7Most Valued Member
Mines on the right, but I did add an second "arm" to the standard setup.
I haven't got around to fitting a scale to the quill yet so that's not an issue for me yet
I stand on the right as I can hit the e/stop with my knee and my X power feed is on the right(though they can be fitted either end right??).
On the left hand side you'll either be pressing buttons with your left hand or twisting to use your right(not a huge deal most of the time on a DRO).
25th Apr 2021, 11:06 PM #8
Thanks Stuart thanks for the feedback.
I also added another arm many years ago, as well as to the lathe.
I have had the knee power feed on the left for over 10 years along with the Y power feed handle to the left as well.
I'm both right and left handed, though I write right handed.
My E stop will be where I put it comfortably, easy to reach.
25th Apr 2021, 11:41 PM #9
I'm going with this type of design, only chrome handle lol.
It will have 2x potentiometers and 2 RPM displays, not sure about jog buttons as I don't use them now.
I would have liked the LCD display instead but they where not available back then, I've have recommended them to others who have bought them. They have only really came out the last few years so time will tell.
This 5 axis on the mill and the 4 axis on my lathe are running great for around 9 years now, and the seller sent spare boards as the calculator had a mishap, so should be right for the next 9 years at least, lol.
Dave J
26th Apr 2021, 05:20 PM #10Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
All
I do not have a DRO on my lathe, but I would definitely fell uncomfortable looking to my right for the controls. This is because after driving a car for about 47 years on the left hand side, I am too used to looking to my left for road signs, 2 rear vision mirrors, radio & A/C controls. This would probably be the opposite for people in countries who drive on the right hand side of the road.
JohnQ
26th Apr 2021, 09:12 PM #11
I've never left Australia but actually feel uncomfortable looking to the right myself, that's why I posted about it.
I looked into it years ago but never changed anything.
Just lately it's been bugging my using the mill, and I'm also just about to build this control board and install a new electrical cabinet and I don't want to put it all on wrong side and regret it.
If you install a DRO it will open up a whole new world of machining for any machine.
You can machine something in the lathe, measure it and put that number into the DRO either diameter or radius, you then know where your going to reduce the part to size and length you just face it, zero the DRO and you know the exact length, similar on the mill.
Then there is bolt hole pattern on the mill instead of using a rotary table and lots of calculations etc.
I think it was 2007 I bought 2x Miester DRO's and 7 scales after my injury and selling my Motorcross bikes that I couldn't ride anymore, it was $2150 back then as they where new out other than big dollar items out of the USA.
Today you can buy a 2 axis DRO set for a bit over $250 and a 3 axis for just over $300 some cheaper.
I've bought a few more readouts and scales over the years as they got so cheap.
If your screws are worn it doesn't matter at all, as it gives a 100% positive position of that axis. I found one new screw had a small error in one spot that had me clueless to what was going on until the DRO showed it up after fitting.
27th Apr 2021, 01:49 AM #12Senior Member
- Aug 2007
- 292
I don't have a DRO......yet......but maybe someday. Most of the small CNC mills have the controls on the right, mainly I suppose, because most of us are right handed. I would put it on the right for that reason. Having the controls on the left would require me having to move to the left to use the buttons. Awkward. Now seeing as you are setting it up is there any reason you can't make the box on an arm that can swing from one side to the other? Then you could move it to suit you or the work if it is of a size that makes the display hard to read.
Pete
27th Apr 2021, 12:00 PM #13Golden Member
- Apr 2009
- Kingswood
- 930
Another contribution, all my CNC controls are RHS to try and avoid some of the swarf and coolant fling.
Motor controls high on LHS.
Primary E-stop high LHS close to center.
Keep well,
John.
27th Apr 2021, 05:57 PM #14
I put mine on the right hand side because the mill controls are on the left and would foul the DRO readout !Best Regards:
27th Apr 2021, 07:05 PM #15
Thanks I'm going to give the left a go once my current project is done latter this week which I'll post about.
It's been many years since we had a chat or seen each other John.
Hope you and your family are all doing well.
Also thanks for your invitation and kindness some years ago, I appreciated it.
Dave J
Milling machine in NSW
By son of eevil in forum WANTED TO BUYReplies: 0Last Post: 8th May 2020, 04:58 AM -
CVA milling machine
By welder in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 20th May 2019, 09:25 PM -
Old milling machine
By Alf Scotting in forum METALWORK GENERALReplies: 7Last Post: 26th Mar 2018, 05:46 PM -
HM- 50 Milling Machine
By woodfast in forum METALWORK GENERALReplies: 6Last Post: 7th May 2012, 01:05 AM -
Milling Machine
By R W in forum METALWORK GENERALReplies: 7Last Post: 17th Mar 2011, 09:02 PM
