Results 1 to 11 of 11
Thread: HM 50/52 owners
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Default HM 50/52 owners
    Has any one ran a 100 mm face mill in either there Vertical or Horizontal spindle and if so what results did you get, type of material and max RPM and Depth of Cut and rough feed rate.
    I don't need to know about fly cutter use unless you would like to mention.
    Sent from my T85 using Tapatalk
    Dec 2013
    56
    1,418
    I only run a 67mm one I think it is, but have run a 210mm fly cutter, lol
    Sent from my 5007U using Tapatalk
    Using Tapatalk
    Dec 2013
    56
    1,418
    You will like my next upgrade for the HM52 which I'll post about soon as I'm just finishing it off.
    Still have several other upgrades behind it which I have all the parts for.
    I'll keep you updated.
    Using Tapatalk
    Feb 2013
    Laidley, SE Qld
    1,039
    HM52. I have a Kennametal 7 insert 65mm face mill that I use from time to time but I don't push it. Usually 700RPM, max 1mm DOC in mild steel, hand cranked at what the cutter and mill seem comfortable with. If Sir John had ever used an HM52 I'm sure he would have referred to it as a wet noodle.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Thank you for the replies, I am currently using an 80mm K12 face mill in cast iron, 50 mm cut width, 2.5mm DOC at 80mm/ min, 500 RPM , I need to face 98mm stock and would rather do this in one pass with a similar face mill but at 100 dia.
    The DOC with the 100 would only be about 1mm or less.
    Dec 2013
    56
    1,418
    I think you will be fine using a 100mm, just listen to mill it will soon tell you if it doesn't like a curtaint depth of cut.
    Using Tapatalk
    6,480
    I have a 65 mm, insert side and face cutter, I don't use it ! It grinds, squeals and rattles, I much prefer my flycutter. I can take a 1 mm DOC at 250 rpm in steel without a problem, though I get much less tool wear and a better finish at half that DOC.
    Dec 2013
    56
    1,418
    Are you another member of the club, I think they are called a Chester T universal mill over there in the UK.
    Using Tapatalk
    6,480
    Hi Dave, Guys,
    No ! My mill is an "Optimum" clone, made in the PRC.
    Didn't you see the pictures of the crap that I washed out of the spindle bearings !
    Dec 2013
    56
    1,418
    No I didn't see it.
    Been out of the loop of the forum and only just getting back into it.
    It was just Pipeclay asking for advice on this type of mill I thought you owned a UK clone.
    Using Tapatalk
    6,480
  1. Pullmax owners
    By Alf Scotting in forum METALWORK GENERAL
    Last Post: 20th Jun 2020, 11:55 AM
  2. Aussie AL-960 owners or previous owners input please?
    By befuddled in forum METALWORK GENERAL
    Last Post: 6th Jun 2015, 10:14 PM
  3. A Hercus owners register??
    By neksmerj in forum THE HERCUS AREA
    Last Post: 27th May 2012, 11:22 PM
  4. for the shaper owners
    By fxst in forum METALWORK GENERAL
    Last Post: 19th Apr 2012, 11:27 PM
  5. 24 Hercus Owners and still looking
    By bitza500 in forum THE HERCUS AREA
    Last Post: 24th Dec 2008, 10:39 AM
