Results 1 to 7 of 7
    Apr 2009
    Kingswood
    930
    Default Fine Finished Steel Angle
    I have a small length of steel angle 20x20x3.
    It is not mill finish black steel.
    Dimensions are very close to nominal, all corners are sharp and square, with a finish close to ground.
    This may have been a special made for a particular application, and I just got an offcut.
    Or, it is a manufactured part of an assembly as it has two 3 mm holes drilled through it and the shadow of a mounting point.
    But, it is not painted or finish coated.
    I have seen ground steel plate/bar offered for sale, but cannot remember ground angle.
    Can this material be purchased ?
    If so, where ?
    I am interested in 10 m, to be used in lengths of 750 mm.
    Keep well,
    John.
    7,188
    Might it be stainless? have see SS in this form.
    Apr 2009
    Kingswood
    930
    Bob, magnetic like mild steel.
    Grotty stained appearance just like finely machined steel stored for long periods.
    Tools cut it like MS.
    No sign of tool marks, it is a beautiful finish for a stock material.
    On reflection, it may have come out of a lot of part-made bits for a live-steam locomotive.
    Looks like it might have been meant for a buffer beam.
    It was a typical deceased-estate clean out with me getting the rubbish !
    I am trying to come up with a solution for the footplate edging on a 5" gauge loco under design/construction.
    Two angles rivetted together and machined to shape was one possibility.
    I can machine (vertical mill) lengths up to 750 mm, so I can use black steel.
    Just more work.
    Keep well,
    John.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    John,
    how do you hold it and stop it vibrating when machined vertically?
    Are you using an end mill or carbide cutter in your horizontal spindle?
    Are you able to machine the full vertical face or do you need to stop short top and bottom?
    7,188
    Not much stainless is non-magnetic.
    Like wise some stainless can also get quite grotty and be as soft as MS.
    One test is work hardening.
    Run an old blunt drill bit on it for about 10 s and then try and drill it.
    Apr 2009
    Kingswood
    930
    pipeclay,
    Perhaps my wording was a bit vague.
    My big mill is a vertical turret mill with 760 mm working travel on the X-axis with.
    Have not put any thinking into how to do the job, that is the challenge of a great hobby !
    I will start a project thread soon to describe the construction of the locomotive.
    One of the first discussion areas will be making the footplate edge profile.
    Keep well,
    John.
    Apr 2012
    Healesville
    2,129
  1. Steel Angle 60 Degrees
    By dshcs in forum METALWORK GENERAL
    Last Post: 30th Jun 2017, 02:40 AM
  2. Rubber End Caps for steel angle...?
    By Batpig in forum METALWORK GENERAL
    Last Post: 21st Jun 2017, 11:36 AM
  3. Punching holes on aluminum and steel angle
    By grumpygeek in forum METALWORK GENERAL
    Last Post: 26th Apr 2017, 07:51 AM
  4. pre drilled 'modular' steel angle for shelving
    By adrianjt in forum METALWORK GENERAL
    Last Post: 7th Sep 2011, 06:19 AM
  5. Drilling Steel - Angle of Cutting Face
    By Sacred Cow in forum METALWORK GENERAL
    Last Post: 9th Mar 2008, 10:06 PM
