Results 16 to 30 of 31
20th Apr 2021, 06:37 PM #16Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
25th Apr 2021, 09:29 PM #17Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I finally had a chance to get back to this today.
Stu's idea has been rolling around in my head and I think I can get it to work.
Its the first time I have been confident I can......
Started making the hinge today. Have to 'guess' how much offset I need in order for th pedal to fold out the way.
Prepared to scrap it and make another if I have to.
I bored some 10mm rod with a 3mm hole and cit into 13mm lengths.
mig welded one tab to each pivot.
Will drill a 12mm hole in each plate so the pedal rod fits in the tab before I weld it in place.
Going to scribe lines on thepedal rod so I can re-align the ends before I weld.
Will also fit a offset spring on one side to hold the pedel up or down, soits solid.
https://photos.app.goo.gl/gyggCsv7HXfErpuM6
https://photos.app.goo.gl/gvTupdyzBj34rxA4A
https://photos.app.goo.gl/VEJyZyVdFY3P51im7
https://photos.app.goo.gl/hyRCtEuaWt7summc7
https://photos.app.goo.gl/bsfQLhGYPwvryicv7
30th Apr 2021, 03:08 PM #18Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Did a bit more yesterday and today.
Finally got a mock up done to see if its going to work. Still have to fit it to the car for final fit, but looks good.
Hinged pedal is only 5mm further away from the brake pedal than stock. No one will notice. notice.
Uploaded a vid to U-tube if your interested.
NOTE: Its just tacked together at this stage.
https://photos.app.goo.gl/s1BDscJmtKhc8HEi6
https://photos.app.goo.gl/GV8Z5bMUizXp2rVb6
https://youtu.be/Qumvim9bz3U
Next step is to test fit in car, then fit spring pins, fully weld and then pain.
2nd May 2021, 11:26 PM #19Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I discovered today, I had made a tactical error. I welded the spring pins on fully, before I did a proper test fit IN the car.....doh.
The pedal sweeps too far to the right and hits the kick panel. Probably gone too far to save it , so will probably have to fab another pedal.
I have a spare arm so I can use that and fit it to the same body.
Will orientate the hinge so it pivots vertically, instead of trying to be smart....lol
I job for next weekend now.....
https://photos.app.goo.gl/Y67HUXThoE4Wff4a6
3rd May 2021, 09:30 PM #20Most Valued Member
Well that's a pity.
Just how close is it to working as is?
(bearing in mind it hard to judge distance and angles from here, and I cant see how far it got in your last photo)
By making a hinge a little more complex and it will move the bottom of the pedal towards the driver and towards the center of a car as you fold it.
If you picture replacing the two two pieces of flat black bar you used with two pieces of angle iron, the pedal on one side and the hinge on the other. The pedal will move about twice the length of the the side the pivot it mounted on.
Ok that makes even less sense to me than my last effort, so good luck trying to work that out lol (I'll add a pic once I work out how to knock up a mock up)
I also wonder if it would be better to cut one of your 10mm dia pivots in half so your 3mm bolt is in double sheer.(ok perhaps I'm over thinking things now)
3rd May 2021, 10:04 PM #21Most Valued Member
Does this help? lol
4th May 2021, 02:43 PM #22Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Yes, thanks Stuart. Great help.
I'll have to look a this.
Now, the pedal moves to the 2 o'clock postion, and it clears the body nicely but I then I discovered the kick board is too close and the pedal contacts it before reaching full extent.
New plan is to pivot the pedal to the 12 o'clock position so it rests on top of the body. I am thinking the offset from the hinge I am using now will work for me again with the second attempt. Will have to see.
Will try just a direction change first and see how that goes. If that doesn't work, I'll have to look at a differnt hinge, like you have shown.
5th May 2021, 11:05 PM #23Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
5th May 2021, 11:53 PM #24Most Valued Member
Like this. It is a little trickier to make but should be stronger.
But now that I look at it, unlike yours, tightening the bolt wont do much* and going to four pieces as per the second photo so you can get that adjustment back seems a little over the top.
*if you are using the tightness of the bolt to give some drag?
6th May 2021, 12:07 PM #25Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Ok, that makes sense, thanks.
Not sure my MIG skills are up to spot welding 3 or 4 hinge parts....lol. Hinge is only 25mm wide at this stage.
No reason why I can't go wider, so thats an option.
I am experimenting with bolt tightness at the moment but have not made any conclusions yet.
Will keep it in mind. Can get back to it tomorrow.
SteveLast edited by Sterob; 6th May 2021 at 12:09 PM. Reason: added more info
6th May 2021, 12:22 PM #26Most Valued Member
Steve,
even if you could get the connectors to match, it's highly likely the car wouldn't recognise the pedal on power-up. I don't know how old the car is, but modern German cars (I have a 2014 VW) do a self test on power-up. If the ECU doesn't recognise the part, it's a no-go. My entire reverse camera and park assist system was disabled because one of the beepers had failed. I reckon a part as critical as an accelerator pedal is likely to get a fairly rigorous diagnostic test.Chris
6th May 2021, 04:06 PM #27Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
6th May 2021, 05:52 PM #28
My wife's KIA has a battery voltage sensor ! If the battery is below 10 volts, the car won't start. Jumping it across a fully charged one and it starts OK. They also use a lot of optical sensors as well, boot lid, clutch pedal, doors, just to name a few.Best Regards:
7th May 2021, 10:53 PM #29Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Did a bit more today, after doing the wifes jobs.....
Looked at modifying the same pedal, but it was too much of a hassle to re-join, cut and weld again. Not enough room, so decided to use another pedal I had.
Now, I haven't got another complete pedal but have a collection of parts to assemble one.....Worst case is buy another one on Ebay. Surprisingly. they are not that rare...weird....lol
Anyway, this looks pretty good. Pedal folds cleanly in the car. Will test clearance for my right foot tomorrow.
Thinking of adding a tab to the plug to make it easier to move between pedals. Now is is quite difficult to disconnect from a pedal. easpecially as its in an awkward spot.
It will still lock in, I will just be able to un-lock it without seeing it.
Pedal flex it due to only having ONE fastener holding the pedal in for the test.
https://youtu.be/nQVVmVhDoH4Last edited by Sterob; 7th May 2021 at 10:54 PM. Reason: more info
9th May 2021, 06:18 PM #30Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
HI Guys,
I think I'm done with the fabricating. It looks pretty good but we will see.....
The idea is when wifey wants to drive, I disconnect the cable from the LH pedal and plug into the RH pedal and flip it down.
Sounds easy, but in practice its very hard to reach the connector, even when I sit on the ground! Its dark and there is very little room.....
Considering making a switching loom up sp I can electrically select either pedal. Just need to source a 6 pole, double throw switch or relay.
Ive heard that being done before so not expecting problems, as long as soldering and the contacts are good quality. I already have the right connectors.
Will see if I can get it approved for use now. ( not looking forward to that....)
https://photos.app.goo.gl/1wjZ5152iiMeT2KT8
Tig brazing rods v's Oxy rods. Any difference?
By Zumanity in forum WELDINGReplies: 8Last Post: 13th Mar 2020, 09:21 AM -
4 facet sharpening problems, ER40 collet block doesn't hold the drill concentric
By johntopp in forum METALWORK GENERALReplies: 12Last Post: 11th Apr 2016, 10:43 AM -
Lock up
By A Duke in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 21st Jul 2015, 12:02 PM -
Suggestions for making 3 concentric axles
By bloodandsawdust in forum METALWORK GENERALReplies: 12Last Post: 24th Aug 2014, 07:09 PM
