Results 1 to 8 of 8
Thread: Lathe al320 g apron lubrications
15th Apr 2021, 10:09 AM #1Member
- Feb 2021
- Australia Brisbane Qld
- 51
On the top of my apron next to the blue Nikko pen is what looks like a small oil point or grease nipple. I can’t see anything in my manual. It’s easy to lubricate my lead screw because access is a piece of cake. But I have no idea how to grease or lubricate inside the guts of my apron or do I need to partially dismantle it for the purpose of lubrications.? ... trying to post a pic
15th Apr 2021, 10:10 AM #2Member
- Feb 2021
- 51
If image accidentally rotated. Possible grease nipple is at small end of long fat blue Nikko
15th Apr 2021, 01:22 PM #3I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
Not a grease nipple. That's one of the oilers for the carriage slideways, there should be another in the same spot on the back side. Jam the tip of an oil can in there, squeeze away, pumps oil under the carriage. How have you been oiling the bedways previously?
There's a whole bunch of those little oil nipples all over the place, at handwheels, on the tailstock, etc. Can't see the top of the cross slide on H&F site, but the AL335 has them there as well.
As far as lubing the apron goes, I'll have to leave that for someone else - a quick look at the manual suggests it might be packed with grease upon assembly though.
15th Apr 2021, 01:31 PM #4Member
- Feb 2021
- 51
Thanks Jekyll. I have been spaying the ways with crc or similar when required but now I’m much more serious about useing the correct lubricant in the right spots and as often as should be done. I been a bit slack so far. But now I’m going to bee seeking out all those oil holes
15th Apr 2021, 01:42 PM #5I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
Have a good look around inside the change gear cover while you're hunting down oilers. The AL335 and other 12x36 machines have one in there half hidden behind something or other (behind one of the change gears I think). You may or may not have the same on your machine.
15th Apr 2021, 01:48 PM #6Member
- Feb 2021
- 51
Thanks Jekyll I sprayed some sticky lube on those change gears this morning but did not think to look for oiling points. I’ll do that now and I note that u said it may be partially obscured by the gears so I’ll have a proper look
15th Apr 2021, 05:22 PM #7
Hi Steve,
The way to prevent the forum rotating your pictures is to get rid of the "EXIF" data stored in them by your phone/camera !
I do this by editing the picture and re-saving it. Simply re-saving the picture doesn't work you have to edit it in some way, I normally just crop the edges off and then save. This will get rid of the "EXIF" data and then the forum will leave the picture in whatever orientation you choose.
HTH.Best Regards:
16th Apr 2021, 04:21 PM #8Member
- Feb 2021
- 51
Thanks baron. All these little tech tips come in handy
AL-54B lathe (Hafco) - apron gear wanted
By nadroj in forum WANTED TO BUYReplies: 2Last Post: 8th Dec 2020, 09:13 PM -
Hare & Forbes AL320 Lathe
By Big Shed in forum METALWORK GENERALReplies: 1Last Post: 24th Jul 2010, 10:07 PM -
Oil for Lathe Gearbox/Apron
By markjaffa in forum METALWORK GENERALReplies: 13Last Post: 12th Mar 2010, 04:33 PM -
AL320 lathe milling attachment question?
By ademan in forum METALWORK GENERALReplies: 2Last Post: 3rd Dec 2009, 05:58 PM -
Hercus lathe, remove saddle and apron?
By neksmerj in forum METALWORK GENERALReplies: 6Last Post: 8th Feb 2008, 07:02 PM
