Results 1 to 7 of 7
Thread: Router Bits
11th Apr 2021, 01:40 PM #1Diamond Member
- Sydney, NSW
- 1,249
Router Bits
G'Day,
I want to cut a few profiles in aluminum.
What router bits is anyone using?
I'm thinking of trying these:
https://www.bunnings.com.au/ultra-6-...t-set_p6372550
Ben.
11th Apr 2021, 02:20 PM #2Senior Member
- Perth, Western Australia
- 67
- 362
I have used their straight bits 4,6 and 12mm on aluminium with good success. For the amount of work I do they are fine. If I was doing a lot of work I would step up to something better.
Keep up the lubrication.
Watch the 12mm size it can get away from you if not careful.
Tony
11th Apr 2021, 02:32 PM #3Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
They’ll work.
My personal preference is Freud, but since Bunnings stopped selling them they are harder to get.
11th Apr 2021, 06:20 PM #4
Hi Ben, Guys,
I've used those router bits many times as milling cutters, even on steel ! You do have to be a bit careful though. I found that it was not difficult to bend the 1/4" inch shaft of them ! If you can get the 1/2" inch shaft ones they are much better. They are good on aluminium and brasses, but because there is no rake on them the material you are machining, gets scraped away rather than cut. They are, at least the ones with straight blades, easy to sharpen.Best Regards:
13th Apr 2021, 05:11 AM #5Novice
- May 2013
- close
- 24
I use truacut router bits at work in wood.
We don't bother with the bunnings ones as they go blunt so quickly.
Never tried aluminium but the difference for us in wood is drastic.
17th Apr 2021, 12:11 AM #6Member
- Feb 2021
- Australia Brisbane Qld
- 51
Sometimes I have bought the chwdp ultra bits from Bunnings and sometimes I have bought proper expensive ones from Bunnings. I have definitely noticed the quality difference between them I’m talking wood only never tried them on ally
18th Apr 2021, 10:42 PM #7Diamond Member
- Sydney, NSW
- 1,249
Well did a trial run today. I'm happy with the results. 0.5 mm max cuts off the corners, slow manually feed. I can't remember the rpm. The kit came with a chamfer cutter so I'll try that next.
Ben.
Opinions on Sharpening Router Bits?
By NGrimberg in forum CNC ForumReplies: 3Last Post: 16th Jul 2020, 09:25 AM -
Small HS Router Bits
By electrosteam in forum CNC ForumReplies: 6Last Post: 23rd Nov 2017, 11:54 AM -
Router bits
By phaser in forum METALWORK GENERALReplies: 11Last Post: 1st Mar 2017, 11:14 PM -
router bits in lathe to mill aluminium - youtube video
By steamingbill in forum METALWORK GENERALReplies: 3Last Post: 29th Oct 2013, 06:55 PM
