Results 1 to 10 of 10
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    Default Levelling a turret mill - suggestions ?
    Hi All,
    We put my Turret Mill into place yesterday at work. I checked the table with a Level and it's out a bit, but not massively. I've had a bit of a look online and I found a video on YouTube where the guy is using some screws that are in the threads of the machines base https://www.youtube.com/watch?v=fFDuSUjr7Io . I looked at the threads in my base and with a quick measurement they appear to be M20 and the thread is about 30mm long. I looked at Levelling Feet and found these on eBay https://www.ebay.com.au/itm/Leveling...-/272625382125 another option I thought of is just put some sheet metal shims under it ie 0.9mm, 1.2mm .
    I don't want to bolt it down. I am a bit height restricted, because where we put the Mill is under a Mezzanine but there's enough room to put levelling feet like in the link under the base. What have you guys done to level your Turret Mills ?.
    All The Best steran50 Stewart
    Jul 2006
    Athelstone, SA 5076
    4,255
    I just used shim
    Jun 2005
    Townsville, Tropical Nth Qld.
    225
    I raised mine up by 100mm on hardwood blocks I machined up and then shimmed it with sheet steel. I hate bending over machines. I realise your situation is different though.
    Rgds,
    Crocy.
    near Rockhampton
    6,216
    unless you are setting up workpieces using a level, you do not need to level them.
    Apr 2012
    Healesville
    2,129
    The coolant flows from the chip filled t slots to the outlet better if you give it a bit of a downhill run.
    6,438
    Whilst my mill is a fly weight compared to most, I sat mine on a square of 1/2" thick rubber conveyor belting, the high spots mould into the rubber, the net result is that it doesn't rock and is dead level !
    Well within about 5 mm or so But then I'm on a ceramic tile floor.
    Sep 2006
    53
    1,010
    Thanks for the replies Guys. I agree RC, that they don't need to be levelled as they have a solid base that doesn't move cause movement unlike a lathe's base. It's more a personal preference that the table is reasonably level. My mills table has a coolant outlet on each backside end of the table so the coolant flow shouldn't be an issue. Although the screws like the video would be more accurate, but thats only basically the end of a 20mm bolt sitting on the floor where as I'd rather the base sit on the floor so I'll go with the gal sheet metal for shims. The table height seems ok so I don't think I need to raise it up, but I haven't got to use it yet as I'm waiting for the electrician to move wire it up for me. I'm looking forward to doing some projects with it. Cheers guys
    May 2012
    Dandenong
    76
    I definitely wouldn't be using off the shelf feet with a large mill, you decrease the contact area of the mass which is the most important aspect with a big mill. As others have pointed out, levelling with hard sheet and rubber would give excellent results and help dampen vibration greatly.
    Sep 2006
    53
    1,010
    Quote Originally Posted by aarggh View Post
    Actually no the machine feet would actually increase the contact area. The BM-20E mill that I have has a base like the BM-30A so the contact area is only on the corners and this is about 100mm each way and it's about 12mm thick. The link to the machine feet I had in the thread showed two diameter sizes for M20 threads which were 160mm and 185mm and either one of them has a greater surface area that the contact points of the mill's base. I'm going with sheet metal shims at the moment, just waiting for the local welding shop to cut a variety of thickness for me. If there's vibration with them I'll try some insertion rubber under them and see how it goes. I've erred away from the machine feet at the moment, because both I'm trying to keep the height down and I don't really want to spend $300 if I don't have too.
    6,438
    Hi Stewart, Guys,
    Based on your post, I would definitely go for some 1/2" inch thick conveyor belting ! It will support the whole of the edge of the base, and once settled the machine will be completely stable. I got my conveyor belt from the scrap yard, they have miles of the stuff some of it 2 Mt wide, nearly all of it is 1/2" inch thick, some is 3/4" inch ! It didn't cost me anything other than time to cut a piece off a roll.
    I used a straight length of steel as a guide and a Stanley knife to cut it. It took several goes because you have to cut through the reinforcing fibres between the layers. Mine has two layers of it. Use a wet knife blade as well, it makes it easier to cut. I used a soaked cloth to wet both the knife blade and run into the cut.
  1. CNC Turret Mill - Ballscrew Covers
    By electrosteam in forum CNC Forum
    Last Post: 13th Feb 2020, 11:45 AM
  2. Beaver turret mill - Braybrook VIC
    By OxxAndBert in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 13th Sep 2019, 11:01 PM
  3. Installing a Turret Mill.
    By Old Croc in forum METALWORK GENERAL
    Last Post: 23rd Aug 2017, 11:15 AM
  4. Bridgeport turret mill on ebay
    By steran50 in forum METALWORK GENERAL
    Last Post: 16th Mar 2010, 10:36 PM
  5. Turret Mill
    By sinjin in forum METALWORK GENERAL
    Last Post: 22nd Nov 2006, 10:56 AM
