Results 1 to 7 of 7
Thread: What is this tailstock tool?
5th Apr 2021, 12:03 AM #1I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
I've got one or two things with the Graziano that I've been unable to figure, mostly I think they're just random orphan bits.
This thing however, is driving me nuts, because I've seen a picture of this exact thing before, I think it was in one of the 'shop made tools' type threads on one of the other forums. But while I've seen it before, I cannot for the life of me remember what the point of it was. The obvious answer would be you put tool bits in it, but why on earth would you want to run a toolbit in the tailstock?
5th Apr 2021, 07:07 AM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
The presence of a tang suggests it could be for a drill press?
Maybe the toolbit is a type of custom drill bit?
5th Apr 2021, 07:52 AM #3Philomath in training
- 6,540
I'm thinking you could mount a boring bar (in a square sleeve) in it. For repetitive boring, you could then drill and bore with the tailstock - no cross slide adjustments needed.
6th Apr 2021, 08:25 AM #4Most Valued Member
- 2,651
6th Apr 2021, 09:44 PM #5I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
Could be right I guess, a poor mans turret setup... Just can't shake the feeling there was something more... exciting to do with it, but maybe not.
6th Apr 2021, 11:16 PM #6Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
Used for Broaching in a drill press?
7th Apr 2021, 07:24 PM #7Most Valued Member
- Charlestown NSW
- 1,669
Dont forget there is also a taper in the lathe spindle so maybe this tool could be used for machining something held on the crosslide.
Peter
Help with tailstock
By Briangoldcoast in forum METALWORK GENERALReplies: 7Last Post: 23rd Oct 2018, 11:01 PM -
Tailstock alignment tool - a shameless copy
By variant22 in forum METALWORK GENERALReplies: 13Last Post: 14th Aug 2014, 10:03 AM -
I think it needs a new tailstock
By Burner in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 31st Jul 2014, 11:56 PM -
Tailstock and Bed
By Auskart in forum THE HERCUS AREAReplies: 7Last Post: 12th Aug 2012, 10:01 AM -
Tailstock DRO
By Stustoys in forum METALWORK GENERALReplies: 58Last Post: 11th May 2011, 01:15 PM
