Results 1 to 7 of 7
Thread: Denbigh Milling Machine Type C
28th Mar 2021, 08:59 AM #1New Member
- Mar 2021
- 3
Hi all, just joined this forum hoping to find someone who owns a similar milling machine with an operators / user manual. Alternatively, someone who knows how to use the machine and can guide me on its operation.
Mark
28th Mar 2021, 10:58 AM #2
yes
Hi Mark
I have one but not used it, it is rather in poor shape, been flogged I suspect. . The table is a mess with broken sections of the T slot grooves. I have a Vertical head for it. One gear has broken teeth . i don't know of a manual but the website 'Lathes UK' might help - he charges like a wounded bull though.
28th Mar 2021, 01:00 PM #3Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
Welcome to the forum Mark. I did some googling and came across this these links which someone had on The Hobby-Machinist https://collections.museumsvictoria..../items/1511701 Instruction Sheet - Denbigh Engineering Co. Ltd, Tensioning Belts on "C" Miller, 1945 (museumsvictoria.com.au) Instruction Sheet - Denbigh Engineering Co. Ltd, Removing Table Winding Handle for "C" Miller, 1945 (museumsvictoria.com.au) Instruction Sheet - Denbigh Engineering Co. Ltd, Lubrication of "C" Miller, 1947 (museumsvictoria.com.au) It's not a manual, but it might give you some info.
I meant to say that with those links I did get a privacy warning initially which I ignored and everything seemed ok.All The Best steran50 Stewart
28th Mar 2021, 03:31 PM #4New Member
- Mar 2021
- 3
28th Mar 2021, 05:20 PM #5Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
They aren't a very complex milling machine,on/off buttons or switch for the spindle, 3 or 4 belt speeds (2 leavers at the back, one to unlock the motor adjusting slide other to adjust bet tension) and a back gear for the spindle (leaver on left hand side), and a one way 3-4speed power feed for the table (gearbox on right hand side, feed leaver on front of table). Assume it still has the brass speed labels on it?
If you need to learn how to use a milling machine, 50' or 60's machining textbooks or youtube.
They were the equivalent of today's cheap Chinese machines back in the day, don't expect amazing performance from it.
Pics would be helpful
28th Mar 2021, 05:51 PM #6
28th Mar 2021, 06:47 PM #7New Member
- Mar 2021
- 3
Denbigh milling head
By briany in forum WANTED TO BUYReplies: 0Last Post: 12th Jan 2021, 08:23 AM -
Turret vs bed type milling machine
By Pumpkinate in forum METALWORK GENERALReplies: 13Last Post: 18th Aug 2018, 07:19 PM -
Perrin Freres Moutier S.A. Type U-1 Milling Machine
By FP91 in forum METALWORK GENERALReplies: 0Last Post: 27th Mar 2018, 08:31 AM -
Anyone know of a alternative seller of this type of milling machine
By bwal74 in forum METALWORK GENERALReplies: 6Last Post: 18th Sep 2016, 11:10 AM -
Denbigh milling machine
By morrisman in forum METALWORK GENERALReplies: 15Last Post: 13th Jul 2014, 09:12 PM
