Results 1 to 4 of 4
21st Mar 2021, 12:31 AM #1
WTB: 1Hp - 0.75kW - 2-pole 3-phase motor
I'm looking for a 3-phase motor running at around 2880rpm in as small a frame as I can find. I suspect some sort of waterpump or industrial pump is the most likely candidate. The frame could be longer than common frames, that's fine, But I'd like the diameter of the body to be no more than 5" or 125mm - give or take. Shaft size or length is irrelevant for my planned use.
If someone has such a motor in their shelves and no anticipated use for it, please consider a price for me. I'm also very happy to swap you for a 1440rpm 3-phase motor of similar or larger power. I have several from 0.5Hp to 3Hp that I would let go trade for this.Cheers, Joe
21st Mar 2021, 12:43 AM #2
Hi Joe,
Look around for a "Shower Pump" most are induction motors with powers from 1/2 Hp right up to 1 Hp. Usually 9 mm shaft. 100 mm body diameter. My local scrap yard gets loads of them, often one or both pumps size up. They are usually free to me as long as I take all the brass and bronze parts back to them. That stuff is worth more than the motor and it saves them from stripping them for it. They are always 2880 rpm and easily reversible.
The ones with plastic pumps are often universal motors and are around 5k to 10k rpm, sometimes with a speed controller fitted.
Ahh I've just seen you want 3 phase ! All the ones I've mentioned are single phase.Best Regards:
21st Mar 2021, 07:39 AM #3Philomath in training
I have a 1.5kW 2800rpm, 3 phase (flange mount) but it is 160mm in diameter (plus junction box on one side). Let me know if that is of use...
21st Mar 2021, 08:39 PM #4Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
I have a .55kw that meets your dimensions.
NEW TechTop 0.75 kW Motor 415V 3 Phase 4 Pole, 1420 RPM, Foot Mount
By Girius in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 0Last Post: 26th Apr 2020, 02:23 PM -
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM -
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM -
SOLD: 3 Phase 240V/415 0.75KW motor
By Ch4iS in forum METALWORK - Machinery, Equipment, MARKETReplies: 6Last Post: 14th Jun 2012, 05:51 PM
