Results 1 to 12 of 12
    Sep 2006
    Australind , WA
    58
    1,281
    Default New Stand for BS-5 Band saw
    I have been looking at my BS-5 and have wanted to make a decent stand for it since I bought it.
    Its a bit of a pain, as the cast sides of the base is cantered over 5°.
    Have been going over options on making the stand top to match the bandsaw base, but have not found a 'eureka' option. Every option seems to be more difficult than it should....lol
    Anyone got any ideas?
    https://photos.app.goo.gl/eJdSQo7fbicyM6ZFA
    https://photos.app.goo.gl/cuzBnrPHAdFbFdeo7
    https://photos.app.goo.gl/LQ6cUuhJjMY1typy7
    May 2011
    Murray Bridge S Aust.
    5,958
    Hi Steve, When I did mine I made a frame from 50X50X3 angle with swivel castors on the corners. The back end where the motor sits was splayed back to allow for counter balance, I used 25X5 flat bar cut and drilled with 8mm bolts, then bolted the flat bar to the saw and tack welded to the frame.
    My base was made about 300 wide, it should have been about 400 wide as when I sit on it to use as a vertical, it can be a bit unsteady.
    To minimise the swarf on the floor, I also made a square funnel out of 50mmX1.6 rhs cut so that it formed a channel that was then shaped into a "Y" shape, and attached under the blade, so that most of the swarf would drop into the funnel and into a bucket placed on the base of the saw.
    Will try to remember to get some pics of it all, when I go back to work Monday.
    6,473
    Quote Originally Posted by Sterob View Post
    Hi Steve,
    Here are pictures of mine, there should be a drawing as well somewhere ! I thought that I had posted it. If I can find it I will add it to this post.
    I've just recreated a jpg file from the original DXF file. The dimensions are hard to read so if you want them I can read them from the DXF,
    Mar 2011
    Southern Flinders Ranges
    1,552
    My plan when I get to it is just to weld tabs at the appropriate angle to an RHS frame.
    7,188
    I can highly recommend a some sort of swarf catching arrangement/tray and if you are thinking of possibly adding lube/coolant at some future time make sure that tray can catch all the drips including from the back of the saw when the main arms is lifted into the vertical position (otherwise a whole puddle of coolant forms on the floor). A tray closer to ground level to locate the lube/coolant pump/tank is also worth incorporating.
    One think I noticed about most bandsaw stands is that they are too low so when I added the scarf tray I took the opportunity to jack the saw up by about 65 mm - makes it a lot easier to see what's going on.
    When I bought my then already 30 year old BS4 it was a bit of a Frankensaw.
    The motor was a teeny 1/4HP (not the original) and the original stand had also been modified by the owner by (badly/crooked) welding in the lower tray but it turned out to be good enough to support the lube/coolant pump I added.
    As well as the lube/coolant system;
    - replaced the old wobbly wheels - not sure if even the old ones were originals
    - added a stainless swarf/lube/coolant catcher tray
    - the 1/4Hp motor died after couple of years and it was replaced the motor with a 1/2HP motor.
    - all the (starting to crack and fall apart) plastic knobs and handles were replaced with (partially) blued steel toggle handles.
    - an extension plate/face was added to the vice which in conjunction with an added jack screw enable much shorter stock to be held in the vice.
    - a oil damped plunger was added to control downward cutting speed
    - added transparent gear worm box cover
    - replaced the main switch with a no volt version.
    Despite all this it is now so worn out (guides, motor mount and wheels only just hang onto the blade) it does not cut straight.
    I'm tossing up whether to spend the time replacing the worn bits or getting a new one.
    Sep 2006
    Australind , WA
    58
    1,281
    Thanks Kryn,
    Sounds like a better way to go than what I was going to do.
    Sep 2006
    Australind , WA
    58
    1,281
    Hi Steve,
    Thanks John,
    That looks pretty good. Not sure I'd use 4 castors. Was thinking of just having 2 wheels that raised when the stand was lowered to the ground.
    Extending the rear, for when its raised is a good point too....
    6,473
    Thanks John,
    Hi Steve, Guys,
    I did a WIP thread at the time !
    https://metalworkforums.com/f65/t203...aw-acquisition
    The castors were two pairs that I got from the "reduced price" box in B&Q, they cost me £10 for them. Two wheels have brakes. It is rock solid and is easily pushed around and locked in place as needed.
    I increased the height of the stand before I bought the wheels so the height is 580 mm plus 75 mm the size of the wheels. The bottom of the frame is 666 mm by 400 mm and the top is 180 mm wide. I used off cuts of the square tube for the securing bolts because they were all crooked and the cast iron body is tapered with thickening pads cast around the bolt holes.
    Its turned out an ideal height for me. I also put a chip board shelf in the frame at the bottom.
    Sep 2006
    Australind , WA
    58
    1,281
    Thanks guys.
    I've got some designing to do.
    I bought a coolant pump and tank about 5 years ago and its still in the box. I'll have to bust it out and size a shelf for it.
    I want a coolant tray. Not sure if I'll make one or source a cheap plastic one ( if they exist. ) I saw one plastic one for $102 at Repco!
    Sep 2006
    Australind , WA
    58
    1,281
    Hi Steve, Guys,
    Thanks. I just read through the whole thread!
    Some great info in there I have squirreled away....lol
    7,188
    Thanks guys.
    My SS tray came out of an industrial oven andwas the right width but about 150mm longer than planned - I wanted to keep it that long but I have so little room in the shed I decided to trim it down.
    Its not 316 as the REE magnets I use to strain the return coolant stick to it pretty fiercely.
    Nov 2017
    Geelong, Australia
    57
    2,665
    The tray on my larger HAFCO BS is just a folded and welded mild steel affair - painted on the outside and raw inside.
    No issues with the tray rusting out etc. SS would be nice but definitely not essential.
    I think in general because the surface is all open - the water evaporates out of the residual coolant and leaves the oil behind and stops it rusting.
  1. Hafco band saw BS5
    By pipeclay in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 28th Jul 2018, 09:03 PM
  2. Milwaukee band saw
    By Marc in forum METALWORK GENERAL
    Last Post: 14th Nov 2014, 02:52 PM
  3. Metal Band saw
    By iron bark in forum METALWORK GENERAL
    Last Post: 1st Nov 2012, 07:57 AM
  4. VICTORIA Herless Band Saw
    By ersbruce in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 5th Jun 2012, 02:25 PM
  5. Band saw tension
    By choof in forum METALWORK GENERAL
    Last Post: 8th Jul 2008, 10:29 PM
