Results 1 to 8 of 8
Thread: Gunmetal !
12th Mar 2021, 02:42 AM #1
Gunmetal !
I have a gunmetal die holder where the threads have stripped out of the single screw.
For the life of me I cannot drill the hole out to re-tap it, nor drill a new hole in the other side !
I've tried altering the cutting angles on the 3 mm drill ( the original was threaded M4 ) but all that seems to happen is material just builds up on the cutting edge and the drill just spins.
Anyone have any suggestions please. I do have another die holder I can use though it is the same gunmetal material.
Thanks.Best Regards:
12th Mar 2021, 08:14 AM #2Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Non ferrous drilling
Hello young fellow.
I would use a hand stone to alter the drill flute angle to close to zero rake. This will also give you a sharp edge. Use kero as a lube and 300 rpm. Similar to copper. You only need to remove 10 thou from the drill.
BC
12th Mar 2021, 06:15 PM #3
12th Mar 2021, 10:42 PM #4China
- Dec 2005
- South Australia
- 1,658
I am always been intrigued by "gunmetal" I think I must have seen 50 different metals described as such.
13th Mar 2021, 06:49 AM #5Philomath in training
13th Mar 2021, 08:22 PM #6
Hi Guys, Thanks for the replies
This stuff is a bright silvery colour, a bit like bright lead, its quite heavy as well !Best Regards:
13th Mar 2021, 08:34 PM #7Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Gun metal
Hello again.
Gun metal is usually coppery/bronze in colour. Nickle bronze is often called silver bronze by mistake because of it's silver colour. I am thinking cupro/nickle or monel. Used long ago for corrosion resistance. A sharp drill and high feed pressure. This metal work hardens big time. When I came to industry it was out of favour due to cost but it is tough stuff. Centre punch with a pyramid point punch to let the drill bite.
BC
Next you have to tap it. Or braze in an insert.
13th Mar 2021, 09:01 PM #8
Thanks BC,
I'm rapidly coming to the conclusion that "A" I'm wasting my time and "B" its more trouble than its worth, particularly because I do have another and a new one is only £10.00p
So into the scrap bin with it !
PS. I'll salvage the steel handles thoughBest Regards:
