Results 16 to 18 of 18
8th Mar 2021, 11:47 PM #16Most Valued Member
9th Mar 2021, 12:04 AM #17I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
As far as I can tell, it makes no real difference exactly where the worm is, it appears to be able to float either way by some amount. I guess the only reason I can see for it having adjustments both sides is due to the tight bearing fits - I assume tightening one side with the other loose would press the 'tightened' side on further, and simultaneously pull the whole worm assembly out of the other bearing a bit? So I guess, as far as I can tell, yes I can lock one side and adjust the other, and just whack it with a dead blow if I overdo it.
9th Mar 2021, 10:24 AM #18Most Valued Member
Along the same lines as the last idea in your first post, but thread it to replace one of the lock nuts and have it bottom against the right hand side of the worm part.
If you are worried about it coming undone I have a more complicated idea, but it requires modding the part by machining some sort of hirth joint/dog clutch in the end of your part and making the above "nut" in at least two pieces.
Temporary anti-rust solutions?
By Legion in forum WELDINGReplies: 21Last Post: 3rd Dec 2014, 11:49 AM -
$$$$ please tell me these electrodes are just brilliant
By beefy in forum WELDINGReplies: 16Last Post: 24th Nov 2014, 07:20 PM -
Solutions for cutting bar stock needed
By Michael G in forum METALWORK GENERALReplies: 31Last Post: 21st Jun 2014, 09:25 AM -
Brilliant new respirator! Why didn't anyone think of this sooner?
By Ben Dono in forum METALWORK GENERALReplies: 25Last Post: 16th Mar 2014, 11:37 PM -
Brilliant MIG tutorial site
By Rossluck in forum WELDINGReplies: 2Last Post: 22nd Aug 2008, 11:30 PM
