Results 1 to 10 of 10
Thread: 9.5 LH metric nuts
4th Mar 2021, 12:18 PM #1Senior Member
- Brisbane
- 143
9.5 LH metric nuts
Hi
Anyone in Oz stock M9.5 x 1.5 LH metric nuts ?.. I cannot even find a tap in that size !
4th Mar 2021, 12:27 PM #2Gear expert in training
- 34
- 1,080
I'd be surprised if anyone in the world stocked them...
4th Mar 2021, 12:47 PM #3Senior Member
- Feb 2014
- Werribee, Melbourne
- 178
Those dimensions are close to 3/8" x 16 - what are the nuts from?
4th Mar 2021, 01:28 PM #4Senior Member
- Brisbane
- 143
4th Mar 2021, 01:41 PM #5
Ok ! It sounds like the spinney end to hold the plastic cable drum/dispenser thingy.
Any possibility of machining a suitable spindle that sported a 10 x 1.5 spindle in LH.?
It could be cheaper than having to have a tap made.
Easy peasy to find LH 10 x 1.5 nuts .
Kawasaki trimmer had that size nut.
4th Mar 2021, 01:50 PM #6China
- Dec 2005
- South Australia
- 1,658
Just re drill and tap with something that is available
4th Mar 2021, 08:04 PM #7Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
If it's the thread coming out of the gearbox I would suggest looking at a universal gearbox such as these https://www.ebay.com.au/itm/28mm-26m...frcectupt=true or Multi-Fit Brushcutter Gearbox | JAK Max or GA Spares || UNIVERSAL GEARCASE ASSEMBLY MULTI-FIT INC ADAPTERS . The Jakmax and GA Spares are a lot dearer than the eBay one though, probably actually more than what your Trimmer is worth. I don't recall ever coming across a 9.5LH trimmer head.
All The Best steran50 Stewart
4th Mar 2021, 08:12 PM #8Most Valued Member
4th Mar 2021, 08:43 PM #9Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
3/8 - 16 LH taps are on aliexpress, Tecla&Chiara is one store China Precision Tools is another, $8 or $16 posted.
6th Mar 2021, 09:34 AM #10Senior Member
- Brisbane
- 143
All good .. if i remove the spigot with the PIA thread it leaves me with a M8 x 1 thread coming out of the gearbox. by using the aluminium line head off my Tanaka i have just enough thread to fit the nut.. an M8 x 1 LH nut will be a lot easier to source.
thanks guys
Metric Asian 9x20 lathe needs half nuts
By DavoDavo in forum METALWORK GENERALReplies: 9Last Post: 20th Aug 2020, 10:07 PM -
Specifying T-Nuts
By DSEL74 in forum METALWORK GENERALReplies: 5Last Post: 4th Aug 2017, 10:11 PM -
metric crossfeed nuts for Hercus 260
By jack620 in forum THE HERCUS AREAReplies: 0Last Post: 1st May 2012, 05:34 PM -
T Nuts
By Stustoys in forum METALWORK GENERALReplies: 18Last Post: 28th Jan 2011, 06:25 PM -
Opposing toothed "Clutch-Plate" Nuts? (a bit like "Castle" Nuts...)
By Batpig in forum METALWORK GENERALReplies: 6Last Post: 5th May 2009, 08:18 PM
