Results 1 to 10 of 10
Thread: Tough Drill Belt Guard Swap
1st Mar 2021, 01:01 PM #1.
- 6,459
There is no provision for swapping in the forum's Market Place so I'm asking the question here.
Does anyone have a cast iron spindle pulley belt guard, as per the first photo, from a late model Tough drill they would swap for a pressed steel guard from a similar late model drill?
The pressed guard will not fit a drill equipped with the low speed intermediate pulley. Sharp eyed Tough aficionados will notice the drill in the second photo has the intermediate pulley fitted. The guard had been brutally modified to accommodate the inverted motor pulley. The guard I wish to swap is in good original condition. The guard comes with the essential cast iron rear support mounting which fits onto the motor mounting rails.
Bob.
1st Mar 2021, 10:42 PM #2Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
I don’t have a front cover I’m prepared to part with, but if you want a custom sized tin lid to clear pulleys, I’d be willing to have a crack at knocking some tin for you.
2nd Mar 2021, 12:10 AM #3.
- 6,459
That is a very generous offer Racingtadpole but I have the cast aluminium guard that Tough provided to suit the drill with the intermediate pulley. It's just that I had gotten used to seeing the pulleys on display.
Bob.
2nd Mar 2021, 06:40 AM #4Philomath in training
- 6,563
Darn it Bob! Now you have me thinking about how to make one from scratch from Al.
(Bit of rolling, bit of pressing, bit of welding...)
2nd Mar 2021, 09:38 AM #5.
- 6,459
IMG_20200612_111358919.jpg IMG_20200612_111506045.jpg IMG_20200605_084037744.jpg IMG_20200605_084125665.jpg IMG_20200605_084056719.jpg
The little Tough equipped with the cast aluminium belt guard. I will probably just repaint it, fit it and move onto the next job on the list.
4th Mar 2021, 10:12 AM #6
Wow, great job on the resto. I love the color combo too.
Did you polish the bright steel on a mop wheel?…..Live a Quiet Life & Work with your Hands
4th Mar 2021, 11:19 AM #7.
- 6,459
No Mop.
Thank you Dale.
The column and the spindle have been cleaned up in the lathe using carborundum paper and Scotch-brite. All the other shiny bits are 316 which I gave a wipe over with a Scotch-brite pad. Tough supplied the drill with bright steel fixtures and fittings. I have a problem with corrosion in my shed hence the stainless steel replacements.
The colour scheme isn't some personal whimsy. It is as close as I can get to the original Tough finishes on their late version drill.
Bob.
4th Mar 2021, 11:58 AM #8Member: Blue and white apron brigade
4th Mar 2021, 12:10 PM #9.
- 6,459
Thanks Bob,
I have slowly been assembling the drill in the tin shed. Out of harms way.
My intention is for the drill to end up in the hands of my eldest daughter so I might make up some sort of wooden case to facilitate its storage and transport. I don't really have a use for it given that I have the Waldown 3M.
Bob.
4th Mar 2021, 02:17 PM #10Member: Blue and white apron brigade
Waldown c-0 tool post grinder first run & where does a belt guard mount?
By StrayAlien in forum METALWORK GENERALReplies: 10Last Post: 22nd Jul 2020, 01:16 AM -
Restoration Projects - Tough Drill Press - Dawn Drill Press - Record Pipe Vice
By bwal74 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 10th Feb 2019, 03:11 PM -
Tough Drill, Tough Sale
By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKETReplies: 6Last Post: 27th Sep 2018, 08:26 PM -
Tough drill press
By node105 in forum METALWORK GENERALReplies: 17Last Post: 5th Jun 2013, 05:06 AM -
Vertical belt guard repair?
By neksmerj in forum THE HERCUS AREAReplies: 12Last Post: 5th Nov 2010, 08:54 PM
