Results 1 to 14 of 14
    Feb 2021
    Lincolnshire
    53
    9
    Smile I need a sticky thread!
    Hi folks.
    I'm working on a couple of machinist jacks which are pretty specific to a single job, but I may be able to use them again. They're only simple aluminium rod, threaded with a stainless bolt with the head pressed into another bit of aluminium rod. As I said these are for one specific job, they don't have to last.
    The issue is, with all small jacks I guess, vibrations move the bolt and you lose your support.
    So, what can you ladies and gents suggest for making my threads sticky? I don't want a lock tight, I need to be able to adjust them, but don't want them flopping around.
    On a couple of smaller tests I've tried some thick way oil, basic grease, copper grease, all with varying degrees of failure. I have some no-slip-belt spray somewhere, but I can't find it, that was going to be my next trial.
    Suggestions?
    Many thanks.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Try drilling a shallow hole in the thread, of a diameter to take a small piece of line trimmer cord (or 3D printer filament). Put a small piece of line in and that will provide friction to partly lock things up - bit like a nylock nut.
    Sep 2009
    Newcastle
    342
    Room for a locking nut?
    Jun 2005
    Townsville, Tropical Nth Qld.
    226
    Could you use some thin knurled locking discs on the stainless thread?
    Crocy.
    Oct 2004
    Southern Highlands NSW
    1,898
    I saw a grubscrew that had a shallow slot made along its length, with a plastic strip inserted.
    Also, nylon patched fasteners seem to be getting popular.
    https://www.ndindustries.com/product...king/nd-patch/
    Feb 2018
    Loxton
    54
    37
    Can you incorporate a nyloc into your design?
    Cheers Andrew
    Apr 2012
    Healesville
    2,129
    I know you said that you dont want to use loctite but i thought that i would mention loctite 222, its application is to retain adjustment screws from vibrating out of adjustment and it stays softish so that readjustment is not a problem. They say up to 1/4" but i am pretty sure it still works on larger bolts and might be an easy fix for your problem.
    https://www.henkel-adhesives.com/au/...ctite_222.html
    Dec 2005
    South Australia
    1,658
    Could you slightly crimp the female thread section
    Mar 2011
    Southern Flinders Ranges
    1,555
    A drop of superglue once in place. Bit of heat to break it when you’re done.
    Thread sealing tape will also bind the threads in a non permanent manner
    Jul 2010
    9,088
    I'm not exactly clear what you are trying to do, but damping grease could be called sticky.
    https://www.youtube.com/watch?v=59F9qUDNwnQ
    Nov 2017
    Geelong, Australia
    57
    2,672
    Couple of ideas:
    - roll an O-ring down the threads so it sits in the thread and up against the part it screws into
    - a small cable tie tightened on the bolt thread/shank
    - loctite pipe sealant or aviation gasket sealant (Permatex #3) are non-setting sealants that meet the "sticky" criteria
    7,189
    I've used lanotec grease in this matter in a lo/no vibe application.
    May 2008
    241
    I'm just going to parrot what racingtadpole suggested with using thread sealing tape, cheap to test, just possibly a real bugger to clean away at the end.
    Could also try the thread sealing string I've seen on the shelf at the big green shed, never used it myself but I imagine it does a reasonable job of tightening up a thread.
    Oct 2011
    59
    6,561
    Here's one I prepared earlier (for those who could not understand what I was going on about)
    This is a 3D printed thread that I needed to keep a metal nut on firmly, without preventing rotation.
  1. Favourite Sticky's
    By Yonnee in forum WELDING
    Last Post: 27th Jan 2011, 09:03 AM
  2. Sticky's
    By rogerbaker in forum METALWORK GENERAL
    Last Post: 23rd Jan 2011, 09:58 AM
  3. Favourite Sticky's.
    By Yonnee in forum METALWORK GENERAL
    Last Post: 23rd Jan 2011, 08:50 AM
  4. Sticky wiggler
    Last Post: 30th Aug 2007, 07:52 AM
