Results 1 to 4 of 4
Thread: Setups 2
21st Feb 2021, 12:23 PM #1Senior Member
- Nov 2012
- Mid North Coast NSW
- 422
Setups 2
Sometimes setups can be fun. This one was.
I made this er32 hex collet block a few months ago but wasn't sure the side angles were correct, that's because I got the angles from a couple of triangles cut from plastic on my cnc router.
0.3mm was faced off each side using the BS-0. Watching carefully as it was cutting I could see the plastic triangles are actually pretty accurate.
Notice how the table on my mill is a bit small for me. The tailstock is held with only 1 clamp. Anyone know how to make a mill table longer ? ha ha
21st Feb 2021, 01:12 PM #2Gear expert in training
- 34
- 1,075
21st Feb 2021, 03:11 PM #3Philomath in training
- 6,540
Get some Al plate the size you want and bolt that on as a false table. You could put T slots in or put in a grid of tapped holes that match your hold down bolts.
21st Feb 2021, 08:49 PM #4
Actually that is what a friend of mine did so that he could machine some parts for a Clayton Steam Wagon. He also used a roller stand at one end to support the long length, about 5 feet I recall. Very heavy chunk of metal.
There is a picture of it on line somewhere, if I can remember where !
Home
There is a picture on the front page.
Sorry it was a Foden Steam Wagon. He did do a Clayton. I think that one went to Tasmania, not sure !Best Regards:
Sometimes setups are so awkward
By phaser in forum METALWORK GENERALReplies: 5Last Post: 25th Jan 2021, 01:36 PM
